I think I have fog lights? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2008, 09:06 PM   #1 (permalink)
"Its Camry Bitch"
Dropitmore's Avatar
View Dropitmore's Photo Gallery
Gen5 I think I have fog lights?
About a month ago, I took off my front bumper to put on my SE headlights and noticed wires and plugs behind both ends of the bumper right behind where the fog lights would be....unfortunately I didnt take pics, but does anyone know if Toyota would just leave those back there even if the car doesn have fog lights? I dont even have a fog light switch, and my bumper fog light covers are molded in so they would have to be cut out.....any info would help
Thanks!
Dropitmore is offline   Reply With Quote
Old 03-14-2008, 09:09 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
I think they put the wiring in place for all cars but not the actual lights. It may be easier to wire up all cars during that step of production rather than build all models differently. Also it would make it easier to add them later on if desired by the customer.
2007 Camry 2.4L 5M
Old 03-14-2008, 09:09 PM   #3 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
is yours japan built? i believe the japan built camry's have the removable fog covers with pre-existing wiring also..
MrSo0h0o is offline   Reply With Quote
Old 03-14-2008, 09:13 PM   #4 (permalink)
"Its Camry Bitch"
Dropitmore's Avatar
well mine doesnt have removable covers for sure....sorry if this is a stupid question, but how can I tell if it is japan built? by VIN? I have a gen 5.5, I dont know of too many gen5.5 bumpers that have removable covers....
Old 03-14-2008, 09:14 PM   #5 (permalink)
If the VIN starts with J, it's built in Japan.
2007 Camry 2.4L 5M
Old 03-14-2008, 09:15 PM   #6 (permalink)
netrickyaz's Avatar
View netrickyaz's Photo Gallery
the vin will start with either 1 or 4 to indicate USA and if there molded not removable its a USA built
2005 Toyota Tundra Blue Steel Metallic (SR5® Access 4.7L i-Force V8 with VVT-i)
netrickyaz is offline   Reply With Quote
Old 03-14-2008, 09:17 PM   #7 (permalink)
"Its Camry Bitch"
Dropitmore's Avatar
damn mine starts with a 4...
Old 03-14-2008, 09:19 PM   #8 (permalink)
netrickyaz's Avatar
well i added fogs to mine :P but i wired it in seperately not using the stock because you hasve to buy the new switch which was more then what i had to do myself so...
Old 03-14-2008, 09:22 PM   #9 (permalink)
"Its Camry Bitch"
Dropitmore's Avatar
if thats the case that I do have the ability for plug and play, I wouldnt mind looking into getting the oem fog light arm switch ( sorry, I dont know the term for it)
Old 03-14-2008, 09:28 PM   #10 (permalink)
netrickyaz's Avatar
yea that works easier but you either replace the bumper or use some other form to mount the fogs many people have used metal straps and JB weld etc...
Old 03-14-2008, 09:29 PM   #11 (permalink)
The Connoisseur
CharmCityES's Avatar
i wouldent doubt if it was prewired....it makes production easier that way
and im sure you can find an oem stalk with the foglight switch on ebay....its easy to install too
The "Executive Sedan"
Old 03-14-2008, 09:35 PM   #12 (permalink)
"Its Camry Bitch"
Dropitmore's Avatar
Thats what im talking about.....
Old 03-14-2008, 11:17 PM   #13 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
yep, thats what I did... installed the oem stalk with the fog light switch. and it was definitely easy to install. though, be aware that you may need to buy the relay or the fuse also... the relay was missing from my fusebox. the relays are not easy to get to, they are on the back of the fusebox next to the steering wheel. if you're skinny and flexible enough, you can probably get to it without taking the dash apart.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 03-15-2008, 08:46 AM   #14 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
The Gen 6 is the same, when I installed fog lights I noticed the OEM wiring behind the bumper, unfortunately it doesn't work as there are still missing components, such as the switch and I believe some fuses/relays.
Is this similar to what you saw?
geoff5093 is offline   Reply With Quote
Old 03-15-2008, 10:46 AM   #15 (permalink)
"Its Camry Bitch"
Dropitmore's Avatar
^^^^yes that is similar....so I should only worry about the relay and stalk then right? im looking into taking it to a body shop and having them cut out the covers and mount the fog lights, sounds easy enough....thanks!
