'03 Camry 100k Self-service
Hi All, was hoping to get some advice or tips for a major service I want to do on my '03 XLE 4 with 100k. Was bought Cert. Pre-owned with 48k 2 years ago.
Car has had regular service every 3-6k mile at the quick-lube or Pep Boys in town. Primary driving was ~90 mile commute every day. Oil usually stays fresh looking for quite a while, don't seem to burn any as it stays level.
I was going to replace the spark plugs initially due to some off timbre idling, however returned them once I realized OEM are supposedly good for 120k.
My current plan is to do the following, in this order:
NAPA/WIX airfilter, done.
Seafoaming at 1/3 bottle for intake, 1/3 fuel.
I am concerned that with 100k, there will be a lot of build-up and don't want to screw anything up like valves and such with excessive crud.
After seafoam, throw 1/3 into crank tomorrow and run it for a week or two.
PCV valve replacement.
Change oil to castrol GTX High Mileage, with Mobil 1 filter.
ATF is looking rather sad, so will change with Found Castrol Import ATF T-IV at Autozone for $3.99/qt. Aside from draining on a incline, not sure how to get a real flush of most of the fluid except by doing this a couple of times via dilution. Any tried the seafoam for transmission?
Change the serpentine belt.
Would like to replace the brake fluid, however haven't done this and not sure how to do this for someone with just some stands and wrenches.
Can I bleed each wheel while adding fluid to the resevoir until it comes out clear, and then move to the next one? Unless the dealer changed this before selling as Pre-Cert, then it is original.
Anything else I should consider?
Thanks
