Help- Rhythmic clunk after rotors and brake pads changed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2008, 04:33 PM   #1 (permalink)
View preacherzson's Photo Gallery
I had a pulsation in my steering that the Midas shop said was from my brakes/rotors, so I changed my brake pads and rotors on 3 tires (couldn't get a bolt off the caliper on the pass. rear. I've ordered a caliper w. mounting bracket so I can cut the bolt and replace the rotor/pads on the final wheel.) All seemed good; car drove fine. Later that evening, I hit a major pothole while driving and immediately heard a rhythmic clunking coming from the rear. Sometimes is sounds like it's only from the dr. rear, sometimes it sounds like it's coming from both sides.) So I slowed down and the rhythm of the clunking slowed down too. The clunking comes and goes, usually won't happen above 40mph, and always gets faster if I go faster/slower if I go slower. Also, turning to the right makes it way louder.
Since (at first) I thought it only sounded like it was coming from the pass. rear, I replaced the caliper and bled the brakes bc I thought the caliper might be stuck. Unfortunately the sound came back.
Anyone have any suggestions as to what's making the noise or what I need to check? Did I screw something up on the brake job, or is this noise solely from the pothole hit?
preacherzson is offline   Reply With Quote
Old 03-19-2008, 04:46 PM   #2 (permalink)
Professional BUM for now
2GR_4AG's Avatar
View 2GR_4AG's Photo Gallery
I'd check for any suspension damage due to then pothole...especially on left front since you said noise increased in volume when turning right....check all your suspension joints
and your wheels too.
2GR_4AG is offline   Reply With Quote
