Toyota Camry 2002 LE wheel and door handle question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-22-2008, 03:39 PM   #1 (permalink)
Camry 2002 LE 4-Cyl.
c627627's Avatar
View c627627's Photo Gallery
1. Is this tire mounted correctly on this wheel. It seems there is room between the tire and the edge of the wheel.
EDIT: Yes it is
2. The tip of the driver inside door handle frame is broken. Can it be swapped with the one in the back? Does it pop out or does the inside door frame need to be unscrewed to get to it?
EDIT: It can be swapped with the one in the back but both doors would have to be completely disassembled. Instructions: How to replace Toyota Camry speakers
3. The car's title was originally from California, don't they have tougher standards over there? How do they affect longevity/reliability of the car?
Click on pics for detailed view:
c627627 is offline   Reply With Quote
Old 03-22-2008, 04:18 PM   #2 (permalink)
LoudCamry's Avatar
Gameroom cash: $229327
View LoudCamry's Photo Gallery
if the back and front handle is the same then you can switch it, i believe the tire is correct.
LoudCamry is offline   Reply With Quote
Old 03-22-2008, 04:30 PM   #3 (permalink)
c627627's Avatar
Does it pop out? I don't want to use force if the door needs to be disassembled to get it out.
Old 03-22-2008, 04:36 PM   #4 (permalink)
LoudCamry's Avatar
i am not to sure if it pop out because you will need to remove a wire in the back
Old 03-22-2008, 04:40 PM   #5 (permalink)
c627627's Avatar
Aha, so how is the inside of the door opened. I found one screw (covered) all the way to the right of the handle. Where are the others? Is the dark gray top part the only thing that comes off or the entire inside of the door?
Old 03-22-2008, 04:43 PM   #6 (permalink)
LoudCamry's Avatar
are you now trying to take off the door panel???
Old 03-22-2008, 04:47 PM   #7 (permalink)
c627627's Avatar
No just simply to replace the broken (pictured) part from driver side with the one from the rear.
How do I get to it, to take it out is the question.
Old 03-22-2008, 04:47 PM   #8 (permalink)
Love my Camry
View Engineer2048's Photo Gallery
The tire and rim are ok; what you're seeing is the edge of a steel rim behind the hubcap.
Engineer2048 is offline   Reply With Quote
Old 03-22-2008, 08:45 PM   #9 (permalink)
View james399's Photo Gallery
How do I get to it, to take it out is the question:
http://img128.imagevenue.com/view.ph..._122_823lo.jpg
go get a haynes manual... as for removing that piece... i'm assuming gen 4 cmry.... there will be a little plastic tab on the broken part, pop it open, there is a screw in inside, unscrew and it should pop off...
you do not need to take apart the door pane, and you do not need to undo any wires, the broken part is just a piece of plastic molding around your door...
james399 is offline   Reply With Quote
Old 03-22-2008, 08:47 PM   #10 (permalink)
wha?!?!
Old 03-22-2008, 10:19 PM   #11 (permalink)
c627627's Avatar
James, 2002 is the first 5th generation model.
Is this the plastic tab you're talking about, yes there is a screw under it.
When I get it off, it still feels like there are more screws holding the thing, or should I force it open after getting this screw off:
Old 03-23-2008, 12:28 AM   #12 (permalink)
c627627's Avatar
Never mind, here it is, I think I know what you mean now, click here:
So it's just a matter of removing the inside handle bezel plug, to get to the one screw that's right under the inside handle...
Old 03-23-2008, 04:14 AM   #13 (permalink)
total brain fart... lol... i have an 02... ha ha ha ha.... uh the screw you are point to with the red arrow only needs to be removed if you want to remove the entire door panel...
Old 03-23-2008, 04:18 AM   #14 (permalink)
yessum... thats it, pop off the plastic piece, "inside handle bezel plug,"
unscrew the screw, and work out the plastic piece around the inside handle, "the broken part,"... becareful when pulling it out, you will have to pull on the handle a little and gently work it out...
