yes, it is simple,
first to remove the lower part, just pull up hard on the front of it. in the center of the part where u sit.
once u pop both sides just pull it foward. no bolts no screws nothing,
then the back part, 4 bolts at the bottom i think 12mm bolts.once they are gone just push up toward the roof really hard, it soon pops out. that is it.
here is the 3 lil metal pieces that keep the back of the seat held in place.
once the seat is moved out of the way (se) u cna see the lil plastic and metal pieces that hold the seat.
u can see the bolts in the corner. under the seat belt.
hardest part is getting the back of the seat back on. and getting to bottomparts on top of the metal bar the bolts go in. npot that hard, than juist slide the bottom in and pop it into place.
