Airbag Sensor (underneath hood) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2008, 01:49 AM   #1 (permalink)
View 05camryle's Photo Gallery
Was wondering if anyone could help me out... I had to get two new airbag sensors from Toyota (currently finishing up a wrecked camry rebuild) and was wondering how the heck I get the plug into the module? It's like a retractable plug that is supposed to plug into the unit, but no matter how hard I push it doesn't want to snap in. Is there a hint to this or a special tool I need or something? I'm referring to the actual airbag sensor modules, one on each frame rail of the car behind each front fender.
Any suggestions?
05camryle is offline   Reply With Quote
Old 03-24-2008, 11:09 AM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Post a pick of the plug and module.
2006 Camry LE Special Edition
Old 03-24-2008, 12:38 PM   #3 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $172825
View JSM1284's Photo Gallery
Front Right SensorAir Bag Front RH Sensor
REPLACEMENT
  1. PRECAUTION Observe Air Bag Systems; Service Precautions.
  2. DISCONNECT BATTERY NEGATIVE TERMINAL
  3. REMOVE ENGINE UNDER COVER RH
  4. REMOVE AIR BAG FRONT RH SENSOR
  1. Remove the bolt and front airbag sensor RH.
  1. Disconnect the connector from the front airbag sensor RH. HINT: Insert a screw driver in any of the three opening sections of the sensor and slide the sensor to disconnect it from the connector.
    1. INSPECT AIR BAG FRONT RH SENSOR
    2. INSTALL AIR BAG FRONT RH SENSOR
      1. Check that the ignition switch turn OFF.
      2. Check that the battery negative (-) terminal is disconnected. NOTE: Do not start the operation for 90 seconds after removing the terminal.
      3. Install the front airbag sensor RH with the bolt. Torque: 17.5 N.m (178 kgf.cm, 13 ft.lbf)
      4. Connect the connector to the front airbag sensor RH.
      5. Check that no play is identified.
    1. INSPECT SRS WARNING LIGHT
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 03-24-2008, 03:18 PM   #4 (permalink)
REPLACEMENT
You're the man!!!
Old 03-24-2008, 09:21 PM   #5 (permalink)
Well, I tried it today at the shop with no luck... It doesn't just press on and click like everything else. You have the correct diagram, but it is a special kind of connector that retracts and compresses. I tried using a screwdriver to slide on, as shown - no luck. What gives???
Old 03-24-2008, 10:57 PM   #6 (permalink)
JSM1284's Avatar
Is there an orange piece in the yellow connector?
2005 Lexus ES330
Old 03-26-2008, 06:03 PM   #7 (permalink)
Yes, there appears to be an orange rubber or silicone insert down inside of the connector wrapped around the center peice. I assume this needs to come out?
Old 03-26-2008, 06:09 PM   #8 (permalink)
JSM1284's Avatar
No, I was referring to a plastic pin that is used to lock the connector. Can you take a good pic of the connector?
2005 Lexus ES330
Old 03-26-2008, 06:15 PM   #9 (permalink)
Heh, well either way you pointed me in the right direction... I took a small box cutter knife and wedged it down in there and took the insert out... What do you know, the connector snapped right on!!!
Now I have another delimma, when the car was in the collision, the driver's seatbelt was locked (I guess to prove that he/she was wearing his seatbelt?), and it will not retract. I've removed the molding that goes around the seat belt and exposed the tensioner, or retracter unit, or whatever it is. There is some wiring in there as well. Does this unit have to be replaced? Or is tehre a way to reset it?
Thanks for your help so far, both airbag sensors are now connected and bolted in.
Old 03-26-2008, 06:21 PM   #10 (permalink)
JSM1284;
I sent you a PM message. Thanks so much for your help thus far man. I'd still be scratching my head....... I knew I had the correct part because all of the little channels matched up perfectly but for the life of me could not figure that out!
