Weird thing tonight, lights bounce on bumpy roads - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2008, 08:55 PM   #1 (permalink)
View CheapChic's Photo Gallery
yup, weird. when i go done a somewhat bumpy road, my headlgiht beam bounce on the road in front of me..
anyone,,,
CheapChic is offline   Reply With Quote
Old 03-25-2008, 09:25 PM   #2 (permalink)
View james399's Photo Gallery
anyone,,,
check your headlight to make sure everything is tight, then check the actual bulb to see if it has gotten loose...
james399 is offline   Reply With Quote
Old 03-25-2008, 09:26 PM   #3 (permalink)
Update
Just checked my hid bulb. it is correct H11, and they are turn in all the way, but
they wiggle ever so slightly.. I put an h11 halogen in and tight, but the hid'd are a bit loose. what to do
Old 03-25-2008, 09:47 PM   #4 (permalink)
Update
get new hids... lol... sorry bad joke...
this is what i would do... find something that resists heat, and put it on the bulb, plastic part away from the glass to work as a spacer... as for the material i would use, probably some thick electric tape... you don't have to worry too much about it going in a little crooked or whatevers, cuz you can readjust your headlights to make em straight afterwards...
get what i'm sayin??
good luck... and mad props to you for doing your own shit... i hate it when women call me to fix their cars... lol...
edit: put the tape on the plastic part that will go between the headlight housing and the h11 housing... let me know if that works for you...
Old 03-25-2008, 09:57 PM   #5 (permalink)
OK that is what is wrong. the silicone ring gasket is to small and not fat enought. I might use 2 of those ring gaskets and try to compress it on. I think I will try what you said in the morning. thanks
Old 03-25-2008, 10:34 PM   #6 (permalink)
kooler than da kool-aid
xfyre's Avatar
View xfyre's Photo Gallery
when are you gonna post pics of your ride?
xfyre is offline   Reply With Quote
Old 03-26-2008, 03:09 AM   #7 (permalink)
if that is the case, can you pull it off your halogen h11 and put it onto you hids? i wouldn't put too much pressure, cuz you don't want to crack the plastic housing...
Old 03-26-2008, 08:05 AM   #8 (permalink)
I am lowering it next week and I just gotta new shoes too.
looks too sweet...
Old 03-26-2008, 08:06 AM   #9 (permalink)
good point.. i am doing it this morning.
Old 03-26-2008, 01:36 PM   #10 (permalink)
Joined the dark side. :D
Gameroom cash: $579891
View workerant's Photo Gallery
My HID bounced too.. but not the OEM bulb. It's the bulb. Anyway, my HID burn so in market for new HID.
workerant is offline   Reply With Quote
Old 03-26-2008, 03:55 PM   #11 (permalink)
how'd it turn out...
Old 03-26-2008, 04:36 PM   #12 (permalink)
FIXED: what i did was take off the silicone gasket off the old halogen set and slip it in half. I put it on a bottle and use a razor blade and splite it. Now I have 2 thiner one. I left the original ones on, and then added the 1/2 one to each on top of other gasket.
worked like a dream and the bulb are tight now.
if you get GE hid bulbs, the tolerance is off a bit.
Old 03-26-2008, 05:39 PM   #13 (permalink)
word...
