transmission slipping when warm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2008, 07:38 PM   #1 (permalink)
2003 Camry Speedster
View IPDaily's Photo Gallery
Gen5 transmission slipping when warm
lately i've been noticing that within a few minutes of driving, my car will start slipping from 1st to 2nd and even from 2nd to 3rd... at first i thought this was just worn ATF, but i recently had the tranny flushed, and i've noticed only marginal improvement, if any. is this a typical problem for gen 5 V6's because my car only has 63,000 miles on it, and this is the kind of thing you see on vehicles with 150,000+ miles that need a tranny overhaul... what normally causes this on gen 5's and what's usually involved in fixing this problem? is it normal for a camry with only 60,000 miles on it to need a tranny overhaul?
2003 Toyota Camry XLE V6, 18x7.5" ASA rims +40mm offset, Bridgestone Potenza Tires 225/45/18, H&R Sport Springs, TRD Exhaust/Strut Tower Brace/Rear Sway Bar, Wood Steering Wheel, 20% LLumar Tint
2007 Toyota Camry SE V6, Sport Leather
IPDaily is offline   Reply With Quote
Old 03-26-2008, 10:17 PM   #2 (permalink)
The Connoisseur
CharmCityES's Avatar
theres a TSB for harsh upshift and shifting enhancement for 2002-2003 camrys equipped with the V6
try taking it to the dealer and check into said TSB.
The "Executive Sedan"
Old 03-26-2008, 10:53 PM   #3 (permalink)
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
do you have a link to that information? I might take that to the dealer since i believe I may be having that issue. I just thought it was normal. but when it's warmed up, I get that problem too.
1995 Camry I4 @ 123k Miles - RIP 5-26-07
[Silverado Backed into it]
Originally Posted by catric69 View Post
It's cheaper if you get a new gf.
Gellenole is offline   Reply With Quote
Old 03-26-2008, 11:05 PM   #4 (permalink)
Gen5
yeah i actually had that TSB applied a while back, but interestingly enough, harsh shifting doesn't really seem to be an issue... see what happens is when the car is cold, it seems to shift normally, but after it's heated up, the transmission doesn't seem to want to grab during acceleration in first and second gear, and this makes the car feel sluggish until it gets into third gear then starts shifting more normally....
Old 03-26-2008, 11:27 PM   #5 (permalink)
The Connoisseur
ill look into in as soon as i can
Old 03-27-2008, 03:42 AM   #6 (permalink)
Bootyologist
View 2k4CamThrilla's Photo Gallery
I have a I-4 2004 Camry and it has some harsh upshifts from 1>2 2>3..everytime i ask the dealership bout they say they couldnt find anything wrong with it.
www.myspace.com/djkraz
2009 Toyota Camry SE-(BLK LEATHER,NAVI,Debaged,Blue LED shifter mod,20% Tint)
2004 Toyota Camry LE(SOLD)
1989 Ford Tempo AWD(SOLD)
2k4CamThrilla is offline   Reply With Quote
Old 03-27-2008, 08:57 AM   #7 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
When the transmission was flushed, were chemicals used? If so, flush the transmission again but with ONLY fresh fluid.
You can also try resetting the computer. Disconnect the negative battery cable for a minute or so.
Do you have an MIL? Usually if you're actually slipping there will be a variation in the input and output shaft speeds that the ECM will see.
2006 Camry LE Special Edition
Old 03-27-2008, 01:42 PM   #8 (permalink)
Gen5
no chemicals, just fresh fluid... i had it flushed at the dealership... i've actually did the ECU reset a couple times in the past, but not since before i had the transmission flushed... do you think that it would make a difference being that it's been flushed now? and no i don't have a MIL...
Old 03-28-2008, 09:52 AM   #9 (permalink)
TRD VVTi's Avatar
Gen5
Then it's probably not slipping.
Old 03-28-2008, 11:09 AM   #10 (permalink)
Banned
View TRD_EarBanger's Photo Gallery
Thats a very perceptive and useful comment! But i find that replacing the trans fluid with trans fluid is the most useful repair. Also one time i changed my fluid and my transmission starting running like sh$T! And i was almost ready to post to ask your opinion. But then i found i had indeed left the transmission pan off (overzealous in my car lightening attempts)
TRD_EarBanger is offline   Reply With Quote
Old 03-28-2008, 04:27 PM   #11 (permalink)
Defender of the Universe
View Miranthis's Photo Gallery
My 2005 I4 SE has a soft 1-2 shift especially at low throttle. it is markedly different than the other shifts at same engine RPM etc. It also does not downshift like l would like (it waits too long IMHO) and I end up manually downshifting. The dealer has been through it and it is not a defect, just a characteristic of the model. The dealer said shifting was all electronic and that the TSBs were not for the gen 5.5's. I keep complaining so that if it is going out I have a record.
Jeff
Miranthis is offline   Reply With Quote
Old 03-28-2008, 05:29 PM   #12 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
This is one reason we recommend not to perform a flush service if the vehicle has gone over 60,000 miles and it has never been done.....
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
