Reverse Wire Color and Location??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2008, 07:26 PM   #1 (permalink)
View azngotskills's Photo Gallery
Gen6 Reverse Wire Color and Location???
Well im trying to install an aftermarket navigation system and need to hookup the reverse wire. I tried to search and i find different answers and not one directly for a Gen6 (2008) Camry.
What color is the reverse wire?
Where is the reverse wire located?
Thanks for looking and hopefully i can get it figured out soon
azngotskills is offline   Reply With Quote
Old 03-27-2008, 07:46 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
It should be at the transmission selector reverse switch.
Red in, Pink out.
Isn't that what your Service Manual shows??????????????????????????
Old 03-27-2008, 08:04 PM   #3 (permalink)
Red in, Pink out.
I dont have the service manual....i got all the other wires but dont know how to find the reverse wire (+). Could you please tell me the physical location and color if you know?
Old 03-27-2008, 08:48 PM   #4 (permalink)
View ilovetocamp's Photo Gallery
This is from the instructions I used when I installed my factory unit.
The connector they are talking about is located behind the glove box.
Hope this helps.
Connect the REVERSE Signal (Camry Gasoline
Vehicle):
Locate connector AE3 and find pin 6. Please see the
photo on the left for the location and below for the
connector view. Once pin 6 is located, you will notice that
the wire is coloured GRAY (REVERSE SIGNAL). For
further information, please consult with the TOYOTA
Camry Electrical Wiring Diagram.
AE3
2007 Camry XLE
ilovetocamp is offline   Reply With Quote
Old 03-27-2008, 11:21 PM   #5 (permalink)
instant noodle FTW
INDOMI's Avatar
View INDOMI's Photo Gallery
easy peasy man, open your trunk, take the cover off to reveal the wires for your taillights, and then find the red cable on one of your reverse lights, done
INDOMI is offline   Reply With Quote
Old 03-28-2008, 11:27 PM   #6 (permalink)
View mp04's Photo Gallery
I did the same thing for my Pioneer Z2 in my 07 SE. Just tapped the reverse light wire, so when I put my car in reverse, the back up cam comes up.
mp04 is offline   Reply With Quote
Old 03-29-2008, 12:14 AM   #7 (permalink)
Thanks guys
Old 05-26-2011, 05:42 PM   #8 (permalink)
View MDTRD's Photo Gallery
This may be a dumb question but hooking up the reverse wire would only be for using a back-up cam, correct? I just installed an AVN-6620 in my 09 SE w/JBL and do not plan on using a b/u cam.
Does anyone know which wire to tap to change the illumination when the headlights come on? Yes I used the SEARCH but didn't find anything.
09 Camry SE V6
07 Taco DC TRD OR
06 Sequoia Limited
00 Taco Xtracab s/c'd TRD V6 5sp -- PARTING OUT!!!
MDTRD is offline   Reply With Quote
Old 05-26-2011, 06:40 PM   #9 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
search for my thread called "power sunshade". there's the wire code and location at the door sill
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 05-26-2011, 09:44 PM   #10 (permalink)
Thanks Profuse007. I found the red reverse wire. I've probed every black wire near the fuse box and no juice in anywhere when I turn the parking/headlights on. Any pointers?
09 Camry SE V6
07 Taco DC TRD OR
06 Sequoia Limited
Old 05-26-2011, 10:32 PM   #11 (permalink)
I Eat Accords! W_(^_^)_W
my.rims.are.stock's Avatar
Gameroom cash: $114800
View my.rims.are.stock's Photo Gallery
Talking
Try the other fuse box?
my.rims.are.stock is offline   Reply With Quote
Old 05-26-2011, 10:45 PM   #12 (permalink)
all toyota and honda parking light triggers are negative.
Old 05-26-2011, 11:38 PM   #13 (permalink)
I may try an add-a-fuse off the tail lights and run that to the illumination wire as a very last resort.
09 Camry SE V6
07 Taco DC TRD OR
06 Sequoia Limited
Old 05-27-2011, 03:39 PM   #14 (permalink)
rob1218's Avatar
View rob1218's Photo Gallery
I think the easiest place to get this wire is at the bottom of the drivers kick panel.. it is a red wire that will show 12v when put into reverse..
that way you dont have to run a wire all the way back to the reverse lights..
if your looking for the wire to make your radio dim when you turn your lights on.. you should use the green wire at the radio harness.. it is the thinner gauge of the 2 green wires.. it is the one that is "darker green" opposite corner of the thicker light green wire..
it should go 12v when u turn on your lights.
Most have both positive and negative.. gen 6 camrys also have both.. however the "Positive" parking light wire in the camry connects to a relay that rests at ground(this is pretty uncommon).. so it can only be used for an "Input" to a device.. if you tried to turn on the parking lights with that wire you could pop a fuse.
Let me know if you guys have trouble finding any of the wires... Good luck!
www.toyotanation.com/forum/showthread.php?t=381686
More pics of my car here ^^
rob1218 is offline   Reply With Quote
Old 05-27-2011, 11:22 PM   #15 (permalink)
Thanks rob1218 but I used the green wire w/silver dashes that goes to the seat heater connector in the center console. Works great.
Azngotskills, found mine under the driver's door sill in the bundle of wires. Small red wire.
09 Camry SE V6
07 Taco DC TRD OR
06 Sequoia Limited
