Sylvania 9006CB Did not fit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2008, 11:10 PM   #1 (permalink)
View OddJack's Photo Gallery
Gen5 Sylvania 9006CB Did not fit
I got a pair of 9006cb off ebay but I was suprised to see that they did not fit my Gen 5 camry. It is a little bit larger and would not sit inside the headlight. Plus instead of two parallel fit lines inside the socket it had one in the center. Are there different versions of this bulb? The one I got was 120239107492 on ebay.
OddJack is offline   Reply With Quote
Old 03-27-2008, 11:19 PM   #2 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
I think your trying to fit them into 9005 sockets which are the DRL/hibeams. Which has one center parallel line as oppose to two parallel lines of a 9005 bulb.
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
Old 03-27-2008, 11:22 PM   #3 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Old 03-27-2008, 11:40 PM   #4 (permalink)
oops...hey Liquidi, thanks man. I just installed it on low beam and it fit alright. I installed one side and compared side by side, it's definately whiter. Thanks again!
Old 03-27-2008, 11:50 PM   #5 (permalink)
Gen5 Dome Light
I also put 3022-WHP2 LED in the dome, I recommend this light instead of the stock bulb, it casts a really cool white inside the car.
Old 03-28-2008, 01:16 AM   #6 (permalink)
sky03's Avatar
View sky03's Photo Gallery
should of done the 9005 in 9006 mod for more lumens for ur low beam
96- TSX Retro
07- LED Tails + 4300k HID Kit
sky03 is offline   Reply With Quote
Old 03-28-2008, 08:07 AM   #7 (permalink)
Archosman's Avatar
View Archosman's Photo Gallery
What mod is that?
Archosman is offline   Reply With Quote
Old 03-28-2008, 05:09 PM   #8 (permalink)
sky03's Avatar
Originally Posted by Archosman View Post
What mod is that?
u see how theres 2 parallel lines on the 9005 bulb? all u have to do is shave that off
i did it for my 96
http://www.bmwe34.net/E34main/Upgrade/More_light.htm
theres also the h9 in h11 mod for gen 6 people... who doesent want HIDs
u shave off that parallel line on the h9 bulb
96- TSX Retro
Old 03-28-2008, 09:36 PM   #9 (permalink)
Archosman's Avatar
i did it for my 96
If I read that right will I need to re-aim the lights? I may give this a go when I can afford another set of Silverstars...
Old 03-29-2008, 01:04 AM   #10 (permalink)
sky03's Avatar
it depends on ur headlight housing and how its aimed... u dont really need to re-aim ur lights
silverstars arnt that great, i heard they burn out every few months
i got these these
Replacement 9005/HB3 Bulb, 12V, 65W, each
http://www.rallylights.com/hella/9005.asp
its a $15~ shipped mod if u dont mind the stock color
they do have some 4000k bulbs for $20 or $33 per pair + shipping, but remember they use coats to get this "HID look" so that = less lumens and it says the bulbs burn out quicker
also the 9005 are 65W (+10W compaired to 9006 55W) and they arnt capped at the top
i dont think its a huge enough increase in watt to burn out ur stock wires, but anything can happen so be warned
96- TSX Retro
Old 03-29-2008, 07:15 PM   #11 (permalink)
Forgive meee.
+1 on the 9005 > 9006 conversion. Do it in your fogs too!
2002 Camry LE I4
Old 03-30-2008, 12:43 AM   #12 (permalink)
View danorthface's Photo Gallery
did you read the part where people's headlight housing started to melt? Mine started to turn yellow from the 9005 bulbs, so i switched back to 9006. I don't recommend doing this mod, unless you live in canada where it's cooler.
danorthface is offline   Reply With Quote
Old 03-30-2008, 08:20 AM   #13 (permalink)
Woodzy88's Avatar
View Woodzy88's Photo Gallery
Canada
The reason why he says that is because as soon as you hit the border there is 10ft of snow, we all live in igloos and have sled dogs pulling our sleds. Everyone has a pet polar bear, moose and penguin.
07 Barcelona Red(3R3)Camry SE,2AZ-FE(I4)E351(5M) Smoked LED Tails,Black Halo Headlights,Shaved tail,Black Emblems,TRD TC Short Throw Shifter,TRD Dual Exhaust,K&N Intake,DC Header,UR Front Member Brace,UR Front Tower Bar,UR 23mm Rear Anti-roll Bar,UR Rear Member Brace's
Woodzy88 is offline   Reply With Quote
Old 03-30-2008, 12:12 PM   #14 (permalink)
sky03's Avatar
what car?
96- TSX Retro
Old 03-30-2008, 12:19 PM   #15 (permalink)
'07 XLE
Gen6
It takes a Socialist village..................
