Is my 2.4L on it's last leg?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2008, 06:30 PM   #1 (permalink)
View aaron_c's Photo Gallery
Hey guys, I have a question- first, a little about the car. It's a 2002 Camry, 2.4L auto, with 73k miles on it.
Now, the problem- it smokes (blue-ish) on start-up for a few seconds, and when I accelerated hard to pass someone on my way to wash it earlier today, I got a sulfur-like smell in the car (sunroof was open). On my way home, I opened the sunroof and gave it WOT again to replicate it in a different area (to make sure it wasn't a smell from outside) and I got the sulfur smell again.
The car has been treated very well it's whole life, driven by my mother until a couple days ago (she gave it to me to upgrade to a new Lincoln), so this makes no sense at all to me.
Any ideas on what the problem could be, and whether it could be something simple or serious??
thanks everybody!
aaron_c is offline   Reply With Quote
Old 03-29-2008, 06:32 PM   #2 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
The blue smoke is your valve stem oil seals, my camry does it every morning and whenever it has been sitting for an hour or two. The sulfur smell might be your catalytic converter going bad. That would be my first guess.
BlueFusion6851 is offline   Reply With Quote
Old 03-29-2008, 07:43 PM   #3 (permalink)
The valve stem oil seals- how much will it cost to have them replaced? And how urgent is it?
Old 03-29-2008, 07:52 PM   #4 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
73K is not a problem with Camry. Many drove them way above 100K. Just need some fixing and Ur baby should be good as new.
workerant is online now   Reply With Quote
Old 03-29-2008, 07:59 PM   #5 (permalink)
Yeah, I've always heard that the 2.4's were borderline indestructible, so I wasn't too worried, but I hate that it smokes on startup- I'm a bit of a perfectionist lol. I'm selling my previous vehicle ('99 Dakota), so I'll use some of the cash from that to fix this car up...haven't decided whether I'm going to trade it in and use the $5k or so from the truck to get something a little more sporty like an '03ish maxima, or just hang onto this until I'm out of college.
thanks for the help!
Old 03-29-2008, 08:15 PM   #6 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
The blue smoke on start up after the car sits is probably the valve seals as stated above. Unless you are consuming a decent amount of oil I wouldn't bother fixing it. GM cars used to be notorious for leaking valve seals. I had a Monte SS that gave me a pretty good puff of smoke on start up and I never fixed it. The car started doing that at around 100,000 miles and I drove it to over 230,000 miles, without a problem.
The convertor probably isn't going bad, you are smelling sulfur burning off in the catalytic convertor. Lower quality fuels will many times have a higher sulfur content. Even after using a higher quality fuel for some time, you may still get the smell but it should lessen over time.
2006 Camry LE Special Edition
Old 03-29-2008, 08:22 PM   #7 (permalink)
Oh okay, thanks for the reply! I definitely run the lowest grade of fuel possible lol, so that's probably it.
Old 03-29-2008, 08:25 PM   #8 (permalink)
TRD VVTi's Avatar
Gen5
Why would you do that? Usually gas prices are the same, so you might as well use a quality gasoline like BP/Amoco, Shell, etc.
Old 03-29-2008, 08:31 PM   #9 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Do you mean low grade as in no-name stations or 87 octane rating?
If you mean 87 octane - there's no need to change this unless you notice detonation.
2007 Camry 2.4L 5M
Old 03-29-2008, 09:34 PM   #10 (permalink)
I mean 87 octane- I almost always get it at Wal-Mart or Sams, but I don't know what brand they use.
Old 03-29-2008, 09:39 PM   #11 (permalink)
Mistabullet's Avatar
View Mistabullet's Photo Gallery
Try these brands: Top Tier Gasoline: Retailers
Check out the homepage for more info: TopTierGas.com
Mistabullet is offline   Reply With Quote
Old 03-29-2008, 10:06 PM   #12 (permalink)
I think there's a Chevron near here I can go to- does wal-mart likely use a poor brand of fuel?
Old 03-29-2008, 10:52 PM   #13 (permalink)
Next time you go there check the pumps to see if you can see any brand names such as Conoco or Phillips 66. I believe these two distribute their gasoline to various chains.
I myself use Chevron (87) for my V6, so far so good.
Old 03-30-2008, 12:04 AM   #14 (permalink)
The Connoisseur
CharmCityES's Avatar
i just use 87 octane exxon or mobil gasoline in my car....runs just fine and no sulfer smell...maybe you should try running name brand gasoline and see if the smell stops?
the blue smoke is leaking valve seals...not an urgent detail honestly, unless the car is burning massive amounts of oil
The "Executive Sedan"
Old 03-30-2008, 01:12 PM   #15 (permalink)
View eaglesvr's Photo Gallery
About start-smoke and how I got rid of it
02 camry le 4cyl smoke at startup.
I think that valve seals don't do a big harm and one can live wit that but anyway I'm glad that could handle that. I read that burning excessive oil poisons the cat-converter and o2 sensors.
eaglesvr is offline   Reply With Quote
