Window tinter screwed up - Gotta change the XM antenna location - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2008, 02:45 PM   #1 (permalink)
View CheapChic's Photo Gallery
The Fricken window tinter installed a metallic window tint after he F"N lied to me.
anyway, the XM antenna is in my rear window like this one:
anyway, I am lowering my car this weekend, so I will have access to the wires,
anyone know if this antenna is rated for outside use I want to remove it and place it outside on the rear trunk lid. thanks
CheapChic is offline   Reply With Quote
Old 03-30-2008, 03:26 PM   #2 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
what about mounting it on the front dash?
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 03-30-2008, 03:32 PM   #3 (permalink)
I could, good idea. I was looking at the back and I can just warm the tape and remove it and pull it under the seats and route it up to the outside top of the trunk.
but, don' t know of these an take water exposeure
ps, my xm cut in and out when traveling west. the satelite is at the back of the car then and the tint is blocking the signal
Old 03-30-2008, 04:27 PM   #4 (permalink)
been around the block
View SourDieseL's Photo Gallery
the dash is a nice spot, up in the front by the light sensor seems like a nice area. i think someone has it installed there from the boards as well. I forgot who, but I remember seeing a thread about it.
SourDieseL is offline   Reply With Quote
Old 03-30-2008, 04:45 PM   #5 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $455050
View Luna2's Photo Gallery
I did, minimal problems with fade. It is sitting behind the required inspection sticker. I just tucked the wire against the windshield, down between the dash and A post. I pulled the glove box and tied the cable off to the available wiring, the to the receiver. Sorry you have to move it. Your reception may still be affected by the "tint", more fade points, than without it. GOOD LUCK!!!
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
Old 03-30-2008, 04:49 PM   #6 (permalink)
thanks is the antenna water resistant? anyone
Old 03-30-2008, 04:56 PM   #7 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Mine is, didn't like the "mark" left behind, when it was removed from the 97 Achieva.
Same style, without the plate.
Used velcro to mount.
MFG 02/25/2010
Stock, Shucks!
Old 03-30-2008, 05:46 PM   #8 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Just a thought, put a thin layer of double stick tape on the bottom, before mounting to the outside.
MFG 02/25/2010
Stock, Shucks!
Old 03-30-2008, 07:29 PM   #9 (permalink)
TN User
View ptbr45's Photo Gallery
I just put in my XM system yesterday. My windows are tinted with metallic tint and I haven't seen any issues. My windows have 35% tint.
That antenna should be water resistant. I would be suprised if it wasn't. I was actually very suprised that they had the antenna installed inside the car. Every other XM antenna I have ever seen is designed to be put outside and this is designed the same way as all the others. I thought about putting mine on the trunk but thought I would try it inside.
So I would recommend that you get some adhesive remover (3M makes some...make sure it is ok to use on plastic) and then you will likely need to replace the double stick tape that is on the antenna that you used to attach it to the ground plane. You could leave the ground plane or remove it. Personally I would remove it.
Those are my thoughts.
ptbr45 is offline   Reply With Quote
Old 03-30-2008, 07:36 PM   #10 (permalink)
So I would recommend that you get some adhesive remover (3M makes some...make sure it is ok to use on plastic) and then you will likely need to replace the double stick tape that is on the antenna that you used to attach it to the ground plane. You could leave the ground plane or remove it. Personally I would remove it..
Thanks, I am planning removing the ground plate. On the rear trunk it has enought metal. If you are traveling due west then it cuts in and out.
my windows are 20%. my car is white and I am painting the antenna with white plastic spray paint. just plain white. it will look better.
Old 03-30-2008, 10:25 PM   #11 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
....ps, my xm cut in and out when traveling west. the satelite is at the back of the car then and the tint is blocking the signal
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 03-31-2008, 05:15 AM   #12 (permalink)
Originally Posted by Tobeit View Post
Hey Tobeit... I just got the same wheels for my white toy...same fitment too.
thanks
Old 03-31-2008, 06:38 AM   #13 (permalink)
Take it easy... :-)
Tobeit's Avatar
Old 03-31-2008, 07:51 AM   #14 (permalink)
View tvsjr's Photo Gallery
If he lied to you, tell him to remove the tint as it's not what you wanted, and, by the way, you won't be paying him a dime for either install or removal. If that doesn't work, consider contacting your local police department and discussing "fraud" and "bait and switch" with them. That should motivate him along nicely.
tvsjr is offline   Reply With Quote
Old 03-31-2008, 07:54 AM   #15 (permalink)
I filed a credit card charge back already. To remove the rear tint, it always chances to break the defroster lines, I was told.
