2006 Camry Front door glass vibrating noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2008, 06:15 PM   #1 (permalink)
View chinniahanand's Photo Gallery
USA 2006 Camry Front door glass vibrating noise
I have a 2006 camry LE four cyclinder. I hear some vibrating noise from the the front driver side door glass. I hear this vibration when I hit some bumps. If i lower the window just by a click then the noise seems to disappear. This happens only when the window is completely rolled up. Have any of you had this problem...I took it to the dealer but they were of no help...
I searched the web and found some information. There is also another posting exactly similar to my issue, but the owner reported this on his 2002 camry
http://us.toyotaownersclub.com/lofiv....php/t448.html
I looked up the TSB that he has mentioned on his posting but they apply only for 2002 and 2003 model. Mine is a 2006 model but the problem seems to be exactly the same though...
Can anyone advice me on what I should do? Has anyone had a similar problem?
thanks in advance
chinniahanand is offline   Reply With Quote
Old 03-31-2008, 08:46 PM   #2 (permalink)
View danorthface's Photo Gallery
sounds like an easy fix.. get some weather stripping and put it in the crack where your window glass would roll up. you should be able to do this and not see any weather stripping
danorthface is offline   Reply With Quote
Old 04-06-2008, 03:26 PM   #3 (permalink)
Thank you for your reply....where can I get this weather stripping? can i find it at the parts store? If possible can you post a link for this item? Thanks once again...
