P0128 check engine light code - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2008, 10:11 PM   #1 (permalink)
View sufloyd's Photo Gallery
Hello,
I'm getting a P0128 code on my 2003 V4 Camry. Autozone diagnosis says it's either
a) coolant low level
b) sensor not working correctly
c) thermostat not working correctly.
As part of 90k mile check about 3500 miles ago, the mechanic replaced the coolant. I didn't check the coolant after he had replaced it but I just checked it today and it's about 1 inch below the full level. Is this normal coolant usage considering that it's been about 3500 miles and 3 months since it was last filled?
If the coolant level is okay, then how do I figure out if it's the sensor/thermostat?
Thanks,
Kunal
sufloyd is offline   Reply With Quote
Old 04-01-2008, 10:06 AM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
Originally Posted by sufloyd View Post
Hello,
Thanks,
Kunal
Code P0128 means that the coolant temperature is below the thermostat regulating temperature.
I doubt that you actually used coolant. I'm guessing that there was an air pocket in the system. Fill the coolant to the proper level and check for leaks. What is your engine/coolant temperature?
If the temperature is ACTUALLY low, you will need a new thermostat. If the temperature is ACTUALLY normal but the sensor shows it's low, you need a new sensor.
I'd start with filling the coolant up and clearing the code.
By the way. Your car is an I4 (inline 4 cylinder), not a V4.
Welcome to TN.
Here's cooling system link for you: http://www.camrystuff.com/manuals/Gen5/16_Cooling.pdf
EDIT: Note that the problem could be something else also. It could be a faulty ECM (computer), wiring, etc.
2006 Camry LE Special Edition
Old 04-01-2008, 10:23 AM   #3 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
To add to TRD's explaination:
DTC P0128 COOLANT THERMOSTAT (COOLANT TEMPERATURE BELOW THERMOSTAT REGULATING TEMPERATURE)
CIRCUIT DESCRIPTION
DTC Detecting Condition
HINT:
This is the procedure of thermostat.
If the engine coolant temperature becomes less than 75 °C (167 °F) , it is abnormal.
If not due to the thermostat malfunction, it is abnormal.
Step 1 - 2
INSPECTION PROCEDURE
HINT: Read freeze frame data using the hand-held tester or the OBD II scan tool, as freeze frame data records the engine conditions when a malfunction is detected. When troubleshooting, it is useful for determining whether the vehicle was
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 04-01-2008, 05:40 PM   #4 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
Replace your T-stat and properly "burp" the system and you should be all good.
Nad1370 is offline   Reply With Quote
Old 04-01-2008, 05:53 PM   #5 (permalink)
Crash Test Dummy
View white07cam's Photo Gallery
unless it is the sensor or some other thing then he wasted time AND money...
2007 Super White CE 5-spd. Stock 4 Lyfe, well I have new driver side doors and side pillar.. are those mods?
As of March 1, another $2200 body shop bill due to deer attack..
white07cam is offline   Reply With Quote
Old 04-02-2008, 02:21 PM   #6 (permalink)
Welcome to TN.
Thanks for the tips. Basic question - how do I check the coolant temperature? As in, should I insert a thermometer in the radiator when the car has warmed up after a few minutes ? (but not after a long run, to prevent burns)
Old 04-02-2008, 03:44 PM   #7 (permalink)
TRD VVTi's Avatar
Gen5
Checking the coolant temperature after a few minutes isn't going to do any good at all. After all, it takes quite a while for the cooling system to get hot.
What does your gauge read?
My Prizm (Corolla) had a coolant temp fault code and I noticed that the gauge was running lower than normal. I replaced the thermostat because of that and cured the problem.
Old 04-02-2008, 04:34 PM   #8 (permalink)
Even after an hour's driving, the temperature gauge rises 2 notches up (and no more than that) from the C level. Does this mean it's likely a thermostat issue?
Old 04-02-2008, 04:39 PM   #9 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Yes, very likely as posted before.
Old 04-03-2008, 10:43 AM   #10 (permalink)
TRD VVTi's Avatar
+1
Unless of course, your coolant is so low that the temperature sending unit isn't reading correctly, or the sending unit itself is faulty.
There are still many different things that it could be, but I'm reasonably certain that your thermostat is causing the problem. Don't buy a cheap one. Just get it from the dealer. They're cheap enough anyways.
