20"8x5 +40 offset will it fit? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2008, 11:17 AM   #1 (permalink)
View BoricuaCam's Photo Gallery
Gen5 20"8x5 +40 offset will it fit?
exactly what the title says,will it rub or not with stock springs,whats the best spring for me ,i was thinking tein h since the drop is a inch or less,O im going with 235/35 or 40/20 for tires,,,sorry i allready posted this ? elsewhere,just thought i would get a faster response with a new thread,,promise i wont do it again thx yall
BoricuaCam is offline   Reply With Quote
Old 04-02-2008, 11:49 AM   #2 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
I have 20x8.5 +43mm offset rims with 245-35-20 tires on a gen 6. No rubbing, but I couldn't tell you for sure on a gen 5. BTW it looks like you have 20x8.5 +40mm offset rims.
The way you have it listed is not correct. The first number (20) is the diameter is inches, the second (8.5) is the width of the rim at the tire bead in inches, the third (+40mm) is the offset of the rim in millimeters.
Tire size, first number (245) is the treadwidth of the tire in millimeters, the second number (35) is the sidewall height. 35 means that the sidewall is 35% of the treadwidth. The third number (20) is the diameter.
I'm not really sure what 40/20 means in your post.
Rapid Roy is offline   Reply With Quote
Old 04-02-2008, 12:07 PM   #3 (permalink)
20x8.5 +40mm offset
dam i really messed that up, I meant which is wiser a 35% sidewall or 40% on a 20x8.5 +40mm offset (235/35 or 40/20)
Old 04-02-2008, 12:22 PM   #4 (permalink)
Rapid Roy's Avatar
Oh now is see it.
235/35/20 or 235/40/20. On a gen5 you should stay as low as possible since you are increasing the outside diameter of the tire and changing your speedometer accuracy. Do a search on tire size calculator to see how much error you will have.
Old 04-02-2008, 02:59 PM   #5 (permalink)
I went to 1010tires,I put in the factory specs 16x6.5 +45offset and then put in what im working with and it said inner clearance 20mm less
outer position extend an extra 30mm
To me it seems it might work,what do you think?
