Hid Help!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2008, 10:50 PM   #1 (permalink)
View bhinda11's Photo Gallery
Hid Help!!!
i just got my Hid kit and when i got around to putting it on my car...they gave me a blast and an additional wiring harness the has 2 loose wires on one side and the other side is an h11 plug in for the blast. is the wiring harness from the car suppose to plug into the blast? or do i have to use an additional wiring harness.....thanks for the help and how do i put pics up so i can get better help?
bhinda11 is offline   Reply With Quote
Old 04-02-2008, 11:00 PM   #2 (permalink)
hid
here are the pics
Old 04-02-2008, 11:38 PM   #3 (permalink)
any one here to help?
Old 04-02-2008, 11:46 PM   #4 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
I don't have HIDs but I know a ballast from a blast.
There are hundreds of HID threads in this forum and they all have relevant info in them.
Old 04-03-2008, 12:35 AM   #5 (permalink)
View danorthface's Photo Gallery
if the plug on the ballast is h11, you don't need that wire. If not, then you need to use that wire to plug into your stock wiring.. But to be safe, you really should get a relay harness.
danorthface is offline   Reply With Quote
Old 04-03-2008, 12:44 AM   #6 (permalink)
thanks for the reply man i tried for sum reason it didnt click were can.......i get a relay harness that will have the proper harnesses?
Old 04-03-2008, 04:40 AM   #7 (permalink)
Loving the camry =)
View skyxliner's Photo Gallery
the cable that you have, one end plugs into the ballast and the other side is + and -... that plugs bag into the factory so make sure you get the plus and minus right.... i've swapped it before on accident and didn't damage anything but i definitively wouldn't take my chances again.
relays cheap 25 bucks eBay if you plan on keeping hids long term.
skyxliner is offline   Reply With Quote
