Originally Posted by 03SEDavenport
I think I'm gonna go ahead and just do a basic drain and fill.
Actually that's not a bad idea, but you'll want to do several drain-n-fills.
Buy a case of the correct fluid for your vehicle. Drive vehicle until fully warmed up. Drain transmission fluid & refill. Drive the car for about 30 or more miles. Drain and refill again. Repeat.
I said to buy a case and I am assuming you might comfortably get 3 drain-n-refills out of the case. If you drain 3 qts. each time, you'll get 4. If that's the case, drain it 4 times.
My guess is the former female owner went to Quik-Lube, got the basic oil change and refused all of their other "menu" services. Good for her and maybe lucky for you that they didn't refill your transmission with Pennzoil "Dexron Replacement" or God knows what.
