Originally Posted by aznhyperracer
how do you adjust the shoes? can i do it my self?
thanks
Park your car on a flat surface
Chock the front wheels
Ensure parking brake is not engaged
Lift up the rear end and remove the rear wheels
Put 3 lugs back on finger tight
On the rotor, look for a rubber plug and remove - don't lose this
Rotate the hole in the rotor to 5-7 o'clock position and look inside for what looks like a gear with teeth facing you
Get a screwdriver and rotate the teeth upwards until it stops and the rotor can't turn. If the rotation stops but the rotor still turns, rotate the teeth the other way until it stops.
Rotate the teeth the other way until the rotor can turn freely.
Install rubber plugs, wheels, and lower car
