Guys who did a retro... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2008, 11:07 PM   #1 (permalink)
Cathode Protector
View cosism's Photo Gallery
How are you protecting your bulb adapter? I found this pic in JSM's thread on hidplanet
I need one of those rubber grommet/gaskets and CANNOT find it. I have searched for 1 1/2 hours easily. I seen that lngasman used 3" pvc caps but I wanted something a little more oem looking like this one.... Is this part referred to by a different name so I will know what to search for?
07' SE V6, TSX retro w/ color mod, Chrome 18" GS430 wheels, led bulb swaps, tinted windows, K&N drop-in, Sirius, door moldings(FTMFW!!!!). 2 Britax seats too!
cosism is offline   Reply With Quote
Old 04-07-2008, 11:17 PM   #2 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
I actually did consider doing the PVC or using rubber grommets, but I ended up just trying to make the stock rubber fit over the adapter. It definitely isn't a weather sealed fit, but it's been through almost a year of Chicago weather, ranging from snow and rain, and the HIDs are fine. I have the Philips LVQ ballasts and they have no problem whatsoever, no flicker or dimming or anything.
The headlamp assembly itself just condenses every so often, but it clears up pretty fast.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 04-07-2008, 11:30 PM   #3 (permalink)
View krouchchocolate's Photo Gallery
I used a pvc cap i got from lowes.
krouchchocolate is offline   Reply With Quote
Old 04-08-2008, 06:17 AM   #4 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
i actually PM'ed JSM here and asked a while ago. its referred to as a socket cover off a 2002 Lexus ES300. Make sure you get the halogen version and not the HID. HID version is a solid plastic twist on cap.
try searching at some OEM lexus part stores, the one i had ordered from no longer works apparently.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 04-08-2008, 09:29 PM   #5 (permalink)
Work Hard, Play Later
View LNGasMan's Photo Gallery
I got PVC 3" caps from Lowes. They fit fairly snug and have kept the weather out. I drilled a hole in the bottom for the wires and painted them flat back to match the high beam grommet.
2011 Camry SE - Magnetic Gray Metallic
2011 Rav4 - Black Forrest Pearl
LNGasMan is offline   Reply With Quote
Old 04-08-2008, 10:25 PM   #6 (permalink)
Cathode Protector
Thanks guys. All very helpful advice. LNG, how did you seal the hole you drilled for the wires?
Old 04-08-2008, 11:19 PM   #7 (permalink)
Just a small rubber grommet from the local Hardware store. Either measure what size you need or just take the cap down with the hole already drilled.
Old 04-09-2008, 10:06 AM   #8 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
They are the Low beam cover for a 2002 Lexus ES300 with Halogen lights. They are about $15 from the dealer each.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 04-09-2008, 10:38 PM   #9 (permalink)
Cathode Protector
Thanks for the advice.
Thank you for the reply as well.
I am buying e-coldies for you both!
