My HID Installed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2008, 09:27 PM   #1 (permalink)
Jeet's Avatar
View Jeet's Photo Gallery
Gen6 My HID Installed
Hi TN
Thanks to all who helped me answer all my questions about HID and also the many threads on the forum that helped out noobs about HID . At first i thought it was going to be tough installing the HID (with all the wiring, removing the front bumper and headlights) It turned out to be pretty simple except for a small issue that i ran into, where my HID wasn't able to plug into the OEM headlight harness but i fixed it in the end. Here are two pics i took, just to make sure that the glare is gone or at least acceptable (i hope) since i went with the method of pushing down the flaps instead of using jb-welding it.
This picture was taken upclose against the garage door
This one was taken about 12 feet away from a wall, i pointed out an area shown on the wall, not sure if that are squirrel spotters
Hope someone can give me some pointers if i solve the spotter issue thanks
2007 Camry | 3.5L 2GR-FE | SE |
1997 Corolla | 1.8L 7A-FE | DX |
Jeet is offline   Reply With Quote
Old 04-08-2008, 09:35 PM   #2 (permalink)
Work Hard, Play Later
View LNGasMan's Photo Gallery
You have light leaking out past the squirrel spotters since you just bent tabs down... Need to cover them up with JB Weld or something. That flap inside is just held on at two spot welds, so when you bend it down it pulls away from the shield and light escapes past.
2011 Camry SE - Magnetic Gray Metallic
2011 Rav4 - Black Forrest Pearl
LNGasMan is offline   Reply With Quote
Old 04-08-2008, 09:38 PM   #3 (permalink)
Should be dark above the cut-off like this:
Or this:
Old 04-08-2008, 09:45 PM   #4 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
LNG.. looks like you retro'd...
My Partial Partout!!!
Photo Album
Old 04-08-2008, 09:50 PM   #5 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
You had to remove the bumper and headlamps to install an HID kit? I'm pretty sure that wasn't too necessary unless you did a retro.
Otherwise, good job on it, a little bit of glare though.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 04-08-2008, 09:57 PM   #6 (permalink)
Starting retro #2... D4S with IS350 bi-xenons... Haven't figured a way to make them fit since they are so large and have a 3" lens, so I have RX330 AFS as back-up. The 2nd pic with the blue cut-off is the RX330 AFS with an E30 clear lens.
The D4S ballasts fit nice on the bottom of the jap headlight housings.
Old 04-08-2008, 10:09 PM   #7 (permalink)
Jeet's Avatar
I wasn't able to reach the flap and push it down so i took out the headlight, also by removing the headlight i was then able to reach a frame rail under the headlight which i used to place my ballast. Ah...darn still have some glare...well i hope the glare isn't too bad...gonna try driving behind it and see how bad it is. Thanks guys
Old 04-08-2008, 10:18 PM   #8 (permalink)
boo.hoo.hoo.
desentrix's Avatar
iTrader Score: 6 reviews
View desentrix's Photo Gallery
Good place to place the ballast-- out of the way of the elements.
Re-suggested to use JB weld. You can use coke cans, or higher grade metal for cutoff.
2007 Magnetic Gray Camry LE V6:
Lit door sills, F/R cathode, trunk cathode, K&N SRI, IS250 chromes, LED tails/ bulb swaps, Katzkin leather
desentrix is offline   Reply With Quote
Old 04-08-2008, 10:21 PM   #9 (permalink)
Cathode Protector
View cosism's Photo Gallery
Plus Juan.
07' SE V6, TSX retro w/ color mod, Chrome 18" GS430 wheels, led bulb swaps, tinted windows, K&N drop-in, Sirius, door moldings(FTMFW!!!!). 2 Britax seats too!
cosism is offline   Reply With Quote
Old 04-09-2008, 06:39 AM   #10 (permalink)
sky03's Avatar
View sky03's Photo Gallery
u took the headlight out and didnt do the squirrel mod w/ jb weld?? it only takes like 5 min or so to cover it with jb weld
96- TSX Retro
07- LED Tails + 4300k HID Kit
sky03 is offline   Reply With Quote
Old 04-09-2008, 07:24 AM   #11 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
You're right, you don't need to. I was able to just use my finger for the squirrel spotters and mounted the HID ballasts behind the headlights.
geoff5093 is offline   Reply With Quote
Old 04-09-2008, 09:05 AM   #12 (permalink)
Here and there...
Gameroom cash: $153229
View lammydi's Photo Gallery
This is how my HID cutoff line look after the squirrel spotters are covered.
Here is a link to the DYI thread to cover the squirrel spotters.
HID info
Old 04-09-2008, 10:03 AM   #13 (permalink)
07 Camry SE
View akide's Photo Gallery
ya, you definately need to cover the squirrel spotters with jb weld that's quite a bit of light leakage.. i wouldn't want you to be driving behind me lol
07 Camry SE I4 Hybrid grille, 4300k HID kit, and more
akide is offline   Reply With Quote
