Starting D4S HID Retrofit <PICS> - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2008, 11:59 PM   #1 (permalink)
Work Hard, Play Later
View LNGasMan's Photo Gallery
Gen6 Starting D4S HID Retrofit <PICS>
I've been gathering components for the last few months for this retrofit. The goal, OEM looking HID retrofit with all OEM components.
Here is the Asian style housing that gave me the idea for this. On the early gen6 Japanese made Camry's, the housings have a place to mount a ballast.
So, I tried to find some on ebay and couldn't win any OEM with all the mounting tabs intact. But I noticed the lighted halo lights use the asian style housing. So I bought a pair of the chrome halos.
I then searched for a ballast to fit the underside of the headlight housings and found that the late-model Lexus (06+ IS250/350) use a ballast that fit the dimensions and shape.
These turned out to be D4S, so I also bought some Philips D4S bulbs to go with (cannot use D2S with D4S).
And the bulbs and ballasts needed D4S projectors, so I found some Lexus IS350 bi-xenons.
As you will notice, the IS350 projectors have a large 3" lens and the Camry has a 2.5" lens. The IS350 projector also has a side mounted bulb and is bi-xenon which poses many mounting issues.
So, I have acquired in the past some Lexus RX330 AFS projectors to use if I can't make the IS350 projectors fit.
But I'm not a big fan of bright chrome or lighted angel eye halos, so I will remove those shrouds and install standard SE shrouds when I do the retro. I plan to start with the left side this weekend and will post pics of the progress.
So, a recap of the main components I have to start with:
Pair Halo Headlights
Pair SE Spare Headlights
Pair IS350 D4S Ballasts
Pair IS350 D4S bi-xenon projectors
2x New Philips D4S bulbs
4x RX330 D2S projectors (For back-up - I can modify the D4S bulb to fit)
2x Rolls of Nissan Butyl rubber sealant
4x silica gel packs from HIDplanet
2011 Camry SE - Magnetic Gray Metallic
2011 Rav4 - Black Forrest Pearl
LNGasMan is offline   Reply With Quote
Old 04-09-2008, 12:07 AM   #2 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
I can't wait for your final pictures!!!
Old 04-09-2008, 12:10 AM   #3 (permalink)
phuangk's Avatar
View phuangk's Photo Gallery
Gen6
arrrggg... I wonder what's your total cost for all of those.....
2008 Camry SE 4cyl
phuangk is offline   Reply With Quote
Old 04-09-2008, 12:20 AM   #4 (permalink)
I'll tell you that I won't be telling my wife how much.
Rounded numbers:
IS Projectors = $100
D4S ballasts = $150
D4S bulbs = $100
Halo headlights = $175
SE headlights = $100 for the pair
Having a D4S retrofit done right... Priceless!
Old 04-09-2008, 12:25 AM   #5 (permalink)
phuangk's Avatar
Gen6
Rounded numbers:
D4S ballasts = $150
D4S bulbs = $100
2008 Camry SE 4cyl
Old 04-09-2008, 12:37 AM   #6 (permalink)
Dealers charge upwards of $800 to $1200 for the xenon option when buying a car that comes equipped. I paid $350 for my PNP HID kit last year and was disappointed with the output and all the covering of the squirrel spotters. My D2S retrofit is nice and the output is better than most other HID equipped cars out there - 10x better then the kit, but I want all OEM components for reliability and I made a few novice mistakes when I did my first retrofit (only I notice mistakes). D4S is newer technology so there are fewer spare components for sale increasing the prices. Buying D2S components is much less expensive.
D2S projectors, $60 pair
D2S ballasts, I've seen some go for as little as $20 each.
D2S bulbs, $35 pair.
Old 04-09-2008, 12:44 AM   #7 (permalink)
boo.hoo.hoo.
desentrix's Avatar
View desentrix's Photo Gallery
OMG. Can't wait to see the final result!
2007 Magnetic Gray Camry LE V6:
Lit door sills, F/R cathode, trunk cathode, K&N SRI, IS250 chromes, LED tails/ bulb swaps, Katzkin leather
desentrix is offline   Reply With Quote
Old 04-09-2008, 12:48 AM   #8 (permalink)
kooler than da kool-aid
xfyre's Avatar
View xfyre's Photo Gallery
looks sweet...can't wait for final output pics
xfyre is offline   Reply With Quote
Old 04-09-2008, 09:35 AM   #9 (permalink)
Crash Test Dummy
View white07cam's Photo Gallery
youve definitely put a lot of thought into this, good work so far and good luck!
cant wait to see the final result
2007 Super White CE 5-spd. Stock 4 Lyfe, well I have new driver side doors and side pillar.. are those mods?
As of March 1, another $2200 body shop bill due to deer attack..
white07cam is offline   Reply With Quote
Old 04-09-2008, 09:59 AM   #10 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
Wow... all that for a function that you'll only use for a couple hrs each day... hahaha... the satisfaction better be priceless
Good luck with the project!
My Partial Partout!!!
Photo Album
Old 04-11-2008, 08:45 AM   #11 (permalink)
View 08 SILVER SE's Photo Gallery
please dont leave us hanging. i will be checking back monday to see what you have done.
2008 CAMRY SE
1992 HONDA CIVIC HB 400+WHP
08 SILVER SE is offline   Reply With Quote
Old 04-12-2008, 12:01 AM   #12 (permalink)
I won't forget to update.
My agenda tomorrow after work for this weekend:
1.) Build a mock-up with one of my junk headlights to explore the mounting options with the larger IS350 bi-xenon projector.
Plan A: If it is feasible, then I'll fabricate the brackets necessary to mount them in the headlight housings.
Plan B: If they won't fit, Lexus RX330 AFS projectors. These will be easy as I can use the shield from the stock camry projectors as the mounting brackets in the housings. I've seen this done with the TSX projectors.
Then:
2.) Bake apart the left angel-eye headlight and mount the ballast and new projector.
3.) Install left headlight housing/projector/ballast on car (without lens and shroud) to check alignment, orientation and make final adjustments.
4.) Once all adjusted, install SE shroud and lens and bake back together.
Old 04-13-2008, 08:32 PM   #13 (permalink)
Okay, here's an update of the progress this weekend. I decided against using the IS350 projectors mainly due the the side mounted bulb insertion. So, here are some quick pics of the progress:
Still light outside, so I'll post night pics later.
Old 04-13-2008, 08:46 PM   #14 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Looking good so far!
The RX330 are one of the easiest projectors to retrofit into the Gen6 headlamp housings, fairly easy mounting screws and such. When I did the TSX, it required quite a bit of fabrication, including cutting into the headlamp housing itself to allow it to fit.
Can't wait to see cutoff pictures, it should work great.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 04-13-2008, 09:02 PM   #15 (permalink)
rydr1's Avatar
View rydr1's Photo Gallery
wow! now that is thinking ahead.
nice job man.
rydr1 is offline   Reply With Quote
