Has anyone put Gen5.5 SE V6 (solora rims) on a Gen5 LE? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-10-2008, 12:46 PM   #1 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
Gen5 Has anyone put Gen5.5 SE V6 (solora rims) on a Gen5 LE?
I was wondering since the specs are the same as the is300 rims. 17x7 +50mm would the stock tire size 215/55/17 Fit an a Gen5 Le without rubbing? Since the suspension on the 5.5 SE are different than the Gen5LE. Or should I just stick to 215/50/17 as some people have with those wheel specs. I don't plan to drop or anything.
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
Old 04-10-2008, 06:04 PM   #2 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
suspension isn't that much different between the se and le, not enough that there should be a problem with rubbing with the se rims.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 04-10-2008, 09:29 PM   #3 (permalink)
Forgive meee.
What about between the gen5 and gen5.5?
2002 Camry LE I4
Old 04-11-2008, 02:57 PM   #4 (permalink)
well if they're the same specs as the rims you have on now, there should be no problem at all.
2005 Camry "LE"
Old 04-16-2008, 04:45 PM   #5 (permalink)
Forgive meee.
So which tires do you guys recommend: 215/55/17 or 215/50/17
2002 Camry LE I4
Old 04-16-2008, 11:32 PM   #6 (permalink)
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
i'd use 215/50/17 -- if you got 18's or 19's then i'd do 225/45/18 ; 225/40/19's. I think all of these match up to oem circumference just so that the spedo is not off too much.
1995 Camry I4 @ 123k Miles - RIP 5-26-07
[Silverado Backed into it]
Originally Posted by catric69 View Post
It's cheaper if you get a new gf.
Gellenole is offline   Reply With Quote
Old 04-16-2008, 11:50 PM   #7 (permalink)
"Its Camry Bitch"
Dropitmore's Avatar
View Dropitmore's Photo Gallery
i did 225/50/17 on my SE wheels. I like a little more width on my tires, gives it that sporty yet still low profile look.
Dropitmore is offline   Reply With Quote
Old 04-17-2008, 03:34 AM   #8 (permalink)
Forgive meee.
Whats the offset on the Gen6 SE wheels? +40? I heard that going above 215 would rub with the is300 rims cause they're +50. I really like having 215/55 cause I think it would be a significant difference than what I'm running now. 215/45
Gellenole do you have pics of your setup before your drop? I kinda want to see that 215/50 would look like w/o a drop.
2002 Camry LE I4
Old 05-08-2008, 11:34 PM   #9 (permalink)
Forgive meee.
Well I found a golf side lump on one of my tires today..... So I guess its time to change them all to something I like. I still wonder if I should go with 215/50/17 or 215/55/17?? Anyone?
2002 Camry LE I4
Old 05-09-2008, 12:20 AM   #10 (permalink)
theslowone's Avatar
View theslowone's Photo Gallery
i had is300 rims on my es300,, i had to put a 1/8 spacer in the rear, to clear the 215/50 r 17's , but not when i had z rated tires.
go witha 50 series to get the speedo right
theslowone is offline   Reply With Quote
Old 05-09-2008, 12:36 AM   #11 (permalink)
Forgive meee.
Speedo isn't really a issue for me since even with stock tires they're just as off. What gen was your ES300?
2002 Camry LE I4
Old 05-09-2008, 12:40 AM   #12 (permalink)
theslowone's Avatar
it was a 97 model. u know about 90% camry all stock except for 99 model hid lights and is rims
actuall sold it right after i bought the gen 6 se.
Old 05-09-2008, 12:47 AM   #13 (permalink)
Forgive meee.
Damn that looks good. !
2002 Camry LE I4
