vibration when braking but occasionally - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2008, 01:42 AM   #1 (permalink)
Mr. Ed
sex_&_TRD87's Avatar
View sex_&_TRD87's Photo Gallery
Gen6 vibration when braking but occasionally
like the title stays, when i brake, i feel a vibration. I'm not sure exactly at what speed but it occurs when im braking at the light and i know its not the ABS kicking in cause its not like im slamming it or anything
i know this happened a few months back and so i took it in to get it balanced just to see and the mechanic said that it was good that i got it cause i really needed it and i guess it stoped but like i said, it happens occasionally now
what could be wrong? the only thing i can think of is something with the brakes, dont know what part or balancing whether its the weights or unbalanced air pressure
any ideas? and if it is the balancing, when do i need to balance my tires (mon/miles)? my tires seriously have given me the most problems
Black 2007 Camry LE V6
Current Mods: LED swap, OEM fog lights - 2500K Nokya, 8000K TSX HID retrofits, TRD drop-in air filter, TRD drop, dual Magnaflow Race Series 14851, Sportmax 962 18x8.5 w/ Nankang NSII 225/45/18
sex_&_TRD87 is offline   Reply With Quote
Old 04-14-2008, 01:51 AM   #2 (permalink)
View tweazy's Photo Gallery
Does it vibrate most when braking on the freeway or on a fast brake from 40 mph? If it is then it's your brake rotors. They are warped. You can just get them resurfaced or if not replaced. the stock rotors are pretty cheap.
tweazy is offline   Reply With Quote
Old 04-14-2008, 01:57 AM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $510725
It sounds like warped rotors. If it only vibrates with the brakes, the rotors are warped. If the tire balance was off, it would vibrate at certain speeds but not only when the brake is applied.
2007 Camry 2.4L 5M
Old 04-14-2008, 10:02 AM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
+1
2006 Camry LE Special Edition
Old 04-14-2008, 02:37 PM   #5 (permalink)
Banned
View TRD_EarBanger's Photo Gallery
+1
+2
TRD_EarBanger is offline   Reply With Quote
Old 04-14-2008, 03:59 PM   #6 (permalink)
Mr. Ed
oh that would make sense, didnt think about that, but how would my rotors get warped? and is the warping permanent? cause like i said, when i break at the light, ill feel a vibration BUT it doesnt happen all the time, i wouldnt say very rarely but rare? would the dealer replace under warranty? didnt do anything to the suspension and brakes cept add on the TRD springs
Old 04-14-2008, 04:00 PM   #7 (permalink)
Mr. Ed
thanks everyone!
oh that would make sense, didnt think about that, but how would my rotors get warped? and is the warping permanent? cause like i said, when i break at the light going from 30-40 to 0mph, ill feel a vibration BUT it doesnt happen all the time, i wouldnt say very rarely but not often enough? would the dealer replace under warranty? didnt do anything to the suspension and brakes cept add on the TRD springs
Old 04-14-2008, 05:06 PM   #8 (permalink)
TRD VVTi's Avatar
Originally Posted by sex_&_TRD87 View Post
thanks everyone!
Nearly all the time warped rotors occur from not torquing the lug nuts properly. I've heated rotors so badly that they've cracked, but they never warped.
It is possible to warp them from heat.
If you're in the factory warranty the dealer should resurface the rotors under warranty.
