Headunit installation question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2008, 10:05 PM   #1 (permalink)
View bottlecaps's Photo Gallery
The appropriate harnesses finally arrived in the mail today so I'm starting now with the installation. Already removed the stock head unit, my question now is where is the speed sensor wire located...or a short DIY would be nice if anyone has installed an Avic D2/D3 in their Gen 6. Thanks
And yes, I already searched.
bottlecaps is offline   Reply With Quote
Old 04-16-2008, 09:58 AM   #2 (permalink)
bump *added pics
Old 04-16-2008, 04:33 PM   #3 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
search alittle harder.
Here ya go
speed sense wire?
heres the install on a gen 5
2005 Camry speed sensor wire (vss)
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 04-16-2008, 05:12 PM   #4 (permalink)
View krouchchocolate's Photo Gallery
I dont think you need the speed sense wire for the d3 model. I installed one in my friend's honda civic, and we didn't hook it up, and it was still reading the mph.
krouchchocolate is offline   Reply With Quote
Old 04-16-2008, 06:07 PM   #5 (permalink)
Go camry goooooo
DrewsCam's Avatar
if you want your expected arrival times to be accurate you should connect it
Old 04-16-2008, 06:20 PM   #6 (permalink)
It should be fine. When i had my eclipse double din, I didn't connect the speed sense wire, and the accuracy was fine. Also on my kenwood double din right now, I didn't connect the speed sense wire, and it is working fine.
You should check out the pioneer forum. www.Avic411.com (i think that was it)
Old 04-16-2008, 07:12 PM   #7 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
The speed sensor is probably for dead reckoning. It will probably work fine without it as others have stated. To find the wire, you'd have to look in the service manual.
2007 Camry 2.4L 5M
Old 04-17-2008, 02:50 AM   #8 (permalink)
^^^ I looked...and too much jibba jabba. Gave up on that
Other than that thanks for the replies, got it done
