Originally Posted by ScrooYoo
what do you mean by tall? do you mean the most sidewall? if so, than 215 55 is probably the most sidewall you'll get with 17's
i think he wants as much side wall as possible to reduce fender gap... you can probably go bigger than that, the fender wells are huge on a stock ride height and depending on the width and offset of the rim, you might be able to squeeze some fat tires up in there!!!
edit: the other thing you might want to try, is see who has the largest wheel tire combinations... i.e. find out the tire size of those guys running 22's, then plug it into the miata tire calculator as the stock wheel, and your 17's as the aftermarket and try to get it close....
