Please help me figure out a couple of wires from this Radio Wiring Infomation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2008, 07:00 PM   #1 (permalink)
Camry 2002 LE 4-Cyl.
c627627's Avatar
View c627627's Photo Gallery
I'd like to replace the factory radio on a Toyota Camry 2002 LE: These are the three connectors connected to the factory radio, what does this one on the right do:
c627627 is offline   Reply With Quote
Old 04-29-2008, 07:01 PM   #2 (permalink)
c627627's Avatar
This is supposedly the wiring diagram:
...and these are the actual colors. What is the white/green striped small wire for? (2002 LE has no factory amp)
I figure the rest to be:
• Yellow: Left Rear -
• Black: Left Rear +
• White: Right Rear -
• Red: Right Rear +
Old 04-29-2008, 07:02 PM   #3 (permalink)
c627627's Avatar
These are the actual colors on the other one:
I figure them to be:
• Purple: Left Front -
• Redish (next to green): Left Front +
• Blue: Right Front -
• Green: Right Front +
• Gray: Radio Ignition
• Yellow/blue stripes: Radio 12V
• Brown: Radio Ground
• Small green wire: Radio Illumination
Old 04-29-2008, 07:08 PM   #4 (permalink)
View krouchchocolate's Photo Gallery
the one you are pointing at is the antenna wire.
krouchchocolate is offline   Reply With Quote
Old 04-29-2008, 07:21 PM   #5 (permalink)
c627627's Avatar
Oh OK, thanks for that.
As for the other pics, there are 13 wires in the supposed wiring diagram. I think I figured out 12 but not the white/green striped small wire. The only 13th wire left in the diagram is the factory amp turn on and it says it is pink/blue so it can't be my small green wire especially since there is no amp in the LE version.
I will be installing an amp, so that's why I'm asking...
Old 04-29-2008, 09:09 PM   #6 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
dont cut any of those wires.. go to your local best buy or circuit city or where ever you bought/planning to buy your headunit and pick up the proper wiring harness. The wiring harness will plug into those harnesses and give you bare wire that is color coded to work with and connect to the headunit wires.
MrSo0h0o is offline   Reply With Quote
Old 04-29-2008, 09:16 PM   #7 (permalink)
yes never cut your factory harness. Like the poster above me said. Go to your local cc, best buy and get a harness for the camry. it will be a plug and play thing, and you just match the wires from the harness with the wires from the radio.
