BG-Cleaning my car... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2008, 11:24 AM   #1 (permalink)
Camry Newbie
pedrojqc's Avatar
View pedrojqc's Photo Gallery
Gen6 BG-Cleaning my car...
I was going to put on some BG-Clean into my Car's Evaporator but guess what I don't know where it is of where I should drill the hole (if necessary). Somebody please help.
Here's a pic of what's under the passenger's dash.
If somebody could circle the area or guide me trough I'll really appreciate it.
2008 Camry LE with: Fog Lights/Inchannel Ventvisors/ 4300K HID/ Lip Spoiler/ Nokya Yellow 2500K Fog's/ All interior lightning white LED's / Front Strut Bar/ SE Grille/ K&N Typhoon Intake / TRD Springs / TRD 18" Wheels with 225/45/18 Michelin tires / Future Mod's:TRD Exhaust? ; Razzi Kit.
pedrojqc is offline   Reply With Quote
Old 05-01-2008, 11:49 AM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
The evaporator is downstream of the blower (pressure side).
The outside air (and recirculating intake) comes into the fan from the top (where the cabin filter is.
The ducting you see at the top left of the pic is your heated/coled air to the footwell area.
Old 05-01-2008, 12:00 PM   #3 (permalink)
Camry Newbie
pedrojqc's Avatar
njerald can you take my pic and please circle the area you are referring to? I mean the area where I should place the tap?
Old 05-01-2008, 12:33 PM   #4 (permalink)
'07 XLE
Gen6
Sorry, I've never looked at that area on my car, I can't see the ducting behind the motor from your pic and I don't have my photo editing program on my laptop.
Old 05-01-2008, 12:51 PM   #5 (permalink)
Camry Newbie
pedrojqc's Avatar
^ Thanks anyways...
Can Somebody Help??!!! I would Like to preform this today if possible...
Old 05-01-2008, 01:07 PM   #6 (permalink)
'07 XLE
Gen6
Edited my earlier post.
Do you have the service manual?
Page AC-196 shows how the blower unit hooks up to the AC unit that houses the evaporator and heater radiator.
Old 05-01-2008, 01:40 PM   #7 (permalink)
Camry Newbie
pedrojqc's Avatar
^ yes i have it, will take a look..
Old 05-01-2008, 01:46 PM   #8 (permalink)
'07 XLE
Gen6
Ac-207 also shows the blower exit which goes into the AC unit.
If you drill a hole, you should get air flow out of it when the blower is on.
Old 05-01-2008, 02:01 PM   #9 (permalink)
Camry Newbie
pedrojqc's Avatar
So here is where the hole should be drilled?
Old 05-01-2008, 02:03 PM   #10 (permalink)
'07 XLE
Gen6
Looks like it to me..
Old 05-01-2008, 02:10 PM   #11 (permalink)
Camry Newbie
pedrojqc's Avatar
This is what I understand from the A/C Manual. The air comes in from the outside of the car trough the air cabin filter then trough the Blower and then it gets to the evaporator trough that duct, right? I guess that is the more logic place to drill the hole.
Old 05-01-2008, 02:25 PM   #12 (permalink)
'07 XLE
Gen6
Yes.
Where the evaporator exactly sits in the housing to the left is not very clear from the manual.
Old 05-01-2008, 03:33 PM   #13 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Drilling holes in a car for maintenance is stupid.
In the automotive field, people that do those things are referred to as "hacks" or "butchers".
Inject the cleaning foam through the evaporator drain tube.
2006 Camry LE Special Edition
Old 05-01-2008, 03:57 PM   #14 (permalink)
Camry Newbie
pedrojqc's Avatar
According to the BG-Clean instructions you should leave the evaporator drain port clear. "Make sure it is open and will drain properly"
If you inject the BG-Clean into the drain port how the debris is supposed to get out of you car?
Anyways I did drill the hole and it did the job...The hole isn't noticeable at all.
Thanks, ngerald for your help.
Old 05-01-2008, 04:38 PM   #15 (permalink)
TRD VVTi's Avatar
BG is the only one that I know of that recommends drilling a hole in the case.
It may work the same but I'm not a fan of drilling extra holes anywhere when it can be avoided.
I would think that it works better the way other cleaners are used. That is, injecting the foam through the drain, letting it soak, and then removing the tip from the evap. drain so that the foam which has now turned back into a liquid sweeps everything out with it as it drains out.
