Preventing TRD RSB From Moving Side to Side? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-02-2008, 10:10 PM   #1 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
Gen5 Preventing TRD RSB From Moving Side to Side?
Question for those of you with TRD rear sway bars:
on the stock LE bar, it has metal clamps on the inner side of the bushings to limit/prevent side to side movement. the TRD bar has no such thing, what do you guys use instead? garden hose and hose clamps? i think the lack of those on my TRD bar is wearing out the bushings ... causing the bar to start squeaking fairly quickly after relubing the bushings.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 05-03-2008, 01:35 AM   #2 (permalink)
The Connoisseur
CharmCityES's Avatar
mine doesnt move side to side.....
and im just using poly bushings and modified stock mounts (aka i bent them on the bench vise to fit around the larger TRD bar)
The "Executive Sedan"
Old 05-03-2008, 06:45 AM   #3 (permalink)
i actually did not have to modify the stock mounts... the TRD bar came with bushings with the same OD as stock but larger ID to accommodate the larger bar. my bar is definitely moving from side to side... the bushings have worn away the paint on the curved portion of the bar, close to where it mounts to the body. i'll get a few pictures later today to show you all what i'm talking about.
2005 Camry "LE"
Old 05-03-2008, 09:53 AM   #4 (permalink)
Stock LE Rear Sway Bar:
TRD Rear Sway Bar:
the paint has been worn away on the left side of the left bushing and the right side of the right bushing on the sway bar. you can see the metal clamp that i'm talking about that is present on the Stock LE bar and not on the TRD bar.
2005 Camry "LE"
Old 05-03-2008, 12:07 PM   #5 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Sway bars don't usually have anything to keep them from moving side to side. Any slight movement isn't anything to worry about.
Try using a grease that's intented for the sway bar bushings. It will cling much better than normal greases. You should be able to get it from a suspension company (Hotchkis, PST, BMR, Spohn, Energy Suspension, Prothane, etc.).
2006 Camry LE Special Edition
Old 05-03-2008, 12:25 PM   #6 (permalink)
LoudCamry's Avatar
Gameroom cash: $229327
View LoudCamry's Photo Gallery
didn't the rsb came with 2 little package of grease??
LoudCamry is offline   Reply With Quote
Old 05-03-2008, 03:14 PM   #7 (permalink)
i know the movement is nothing to worry about, but i'm pretty sure that's what is causing my sway bar to start squeaking so quickly after relubing the bushings. the curved end of the bar gets pushed into the bushing, expanding it beyond its normal shape... that's probably wearing out the bushings too.
i recently just switched to using mobil 1 synthetic grease... its pretty thick and clingy so i think it'll help.
2005 Camry "LE"
Old 05-03-2008, 03:15 PM   #8 (permalink)
yes, but i've had the sway bar for a couple years now, those little grease packet wouldn't last that long.
2005 Camry "LE"
Old 05-03-2008, 10:03 PM   #9 (permalink)
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
I just ask the dealer to spray more grease onto the bushings.
1995 Camry I4 @ 123k Miles - RIP 5-26-07
[Silverado Backed into it]
Originally Posted by catric69 View Post
It's cheaper if you get a new gf.
Gellenole is offline   Reply With Quote
