Originally Posted by ve015891
I'm about to get some new rims for my Camry.
Are Hub Centric Rings required? - Yes, if the hub cutout diamater on the rim is larger than your hub diamater on your car. W/o the hub centric rings the wheel mounting only is centered by the bolts, which is not good enough to properly center the wheels on the hub.
How do I know? - Often the mfg gives that number or at least on what cars they fit.
If they are - What size do I get? - They need to fit the hub diameter of your car. I think Gen6 Camry has 60.1mm
Thanks in advance.
You will need to find out what hub diameter size your new rims are and make sure they fit - either directly or by using a hub centric ring to make them fit. I think the new Camry diameter is 60.1mm. Most online rim shops sell the hub centric rings together with their rims to fit your car (like tirerack, discounttire...).
Edit: tried to answer each question...
