Battery Disconnect - Resets
Hi All,
I have researched this forum on this topic, but can't find exactly what I am looking for.
I have an '02 Camry SE 4 cylinder
I was doing some work on my camry over the weekend which called for disconnecting the battery. I didn't know that disconnecting the battery reset the PCM and affected the idling of the car, etc. The Haynes book confirmed this. I also noticed that the battery disconnect caused my speedometer needle to fall all the way forward past the 140 MPH mark. After a few mins of driving, all was back to normal except the speedometer needle. The needle is still all sitting past the 140 MPH mark. No check engine light, the odometer is working fine, and everything else in dash board is working. Car is running like new.
So i disconnected the battery again so I could take out the dash board and manually move the needle of the speedometer to 0 MPH, as well as check if there is anything wrong. Did it, and then reconnected the battery. Looked at the speedometer, and the needle was once again sitting passed the 140 MPH mark! It moved from where I had set it at 0 mph. What gives? Is there some kind of reset required for the speedometer? Will it fix itself after some more driving time? I have been searching the net and cant find anything.
Any help would be greatly appreciated.
