How to lower the glovebox - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2008, 08:47 AM   #1 (permalink)
Gameroom cash: $555540
View Camread's Photo Gallery
Gen6 How to lower the glovebox
sorry for starting a new thread (search didn't come up) I wanted to check the cabin air filter but i couldn't open the glovebox fully. I got the outside side to drop but the other side was too tight. the owners manual said to use pressure but that doesn't seem right.... thanks
to the dark side
Camread is offline   Reply With Quote
Old 05-10-2008, 09:52 AM   #2 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
Then do 20 push ups and try again
The latch should come loose
My Partial Partout!!!
Photo Album
Old 05-10-2008, 10:21 AM   #3 (permalink)
I GOT THE BIG LATCH OK-FINE-NO PROBLEM. but the upper one (window side) is too long to pry it out. stupid owners manual is useless for this one - it shows you grabbing the TOP CENTER of the inner of the glovebox and PULLING IT OUT ya that'll work, if you wanna SNAP the damn thing in half
Old 05-10-2008, 10:46 AM   #4 (permalink)
View ohhey's Photo Gallery
Are you trying to change the air filter ? You take the little damper on the right off the peg on the box. Then you squeeze the box in the center. The back of the box is thin and will bend. As it deforms the two back corners will start to pull inward such that the stop pegs molded into the back will clear the edge they normally catch on. They may scrape by but that is OK. After those clear the box will swing all the way down on the hinges. This is all you need to do to access the filter cover. If you want to remove the box then you will also need to pop the hinges out of place by pulling forward.
When putting it back look under there and make sure the hinges are not poped out any, squeeze the box again and snap it back in. Then pull the damper and hook it back over the peg on the right side of the box. If it doesn't close right get it back out and check the hinges again.
ohhey is offline   Reply With Quote
Old 05-10-2008, 01:57 PM   #5 (permalink)
View moeharri's Photo Gallery
IMHO, it takes a LOT of force to get it to drop down. I was very afraid of breaking it, but decided to just push/pull very hard and it finally dropped. I'm surprised this is the best way they could come up with to drop the glove box.
2007 LE V6 Magnetic Gray, JBL, Moonroof, Toyota Leather Shift Knob, Toyota All Weather Mats, SE Grille, Wheelskins cover
2007 Odyssey EX (traded in 05 XLE I4 Lunar Mist)
moeharri is offline   Reply With Quote
Old 05-10-2008, 04:19 PM   #6 (permalink)
I think getting in forth knox is easier than this. thanks all
(self hi-jack) I have a question about something else. sometimes when i hit a hard bump like a pot hole, the plastic clips (looks like a short nail) under the hood of the gauges gets loosed, which rattles everytime you go over any bad road surfaces and you have to pop it back in. just wondering if this has happen to anybody...
Old 05-10-2008, 04:27 PM   #7 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
Gen6
It's funny you mention that. It has happened to me about a week ago. I took some needle nose pliers to pull them out, readjust them, then popped em back in and haven't had any problems since.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
Old 05-10-2008, 04:31 PM   #8 (permalink)
happened to me twice. of course toyota would say it was designed to do that...
Old 05-10-2008, 07:36 PM   #9 (permalink)
Loving the camry =)
View skyxliner's Photo Gallery
haha it's funny, i just cleaned my cabin air filter.
first latch is easy but the second was impossible. the manual was stupid, using that much force would break the damn plastic. I jsut squeezed my hands in and removed it without any probelms. get someone with small hands!
skyxliner is offline   Reply With Quote
Old 05-11-2008, 12:09 AM   #10 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
+1 I just changed my cabin filter today also. Damn, that filter was dirty!!!
Old 05-11-2008, 03:17 PM   #11 (permalink)
squeezing your hands to unhook the second damper or did you just remove the filter w/o the latches?
Old 05-11-2008, 03:34 PM   #12 (permalink)
View danorthface's Photo Gallery
he squeezed his hands pass the glove box
danorthface is offline   Reply With Quote
Old 05-11-2008, 04:11 PM   #13 (permalink)
boo.hoo.hoo.
desentrix's Avatar
View desentrix's Photo Gallery
Don't forget that before you reattach the 2 latches, and that spring, you need to make sure the bottom hinges is popped in.
2007 Magnetic Gray Camry LE V6:
Lit door sills, F/R cathode, trunk cathode, K&N SRI, IS250 chromes, LED tails/ bulb swaps, Katzkin leather
desentrix is offline   Reply With Quote
