Slipping Power - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2008, 01:57 AM   #1 (permalink)
View FallOutBoyx530's Photo Gallery
Gen5 Slipping Power
My 2005 4 cylinder camry has been getting power issue.
I notice that when I step on the gas lightly, the car doesn't want to move but if I step on it a little more, it jerks forward and feels like it over rev'ed it.
Does anybody know or understand the issue that I have? If so what is the problem or what do you think is the problem so I can fix it myself or take it to a pro.
Thanks for the comments and suggestions.
FallOutBoyx530 is offline   Reply With Quote
Old 05-11-2008, 07:57 AM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Your problem is hard for me to understand.
I'm assuming that the MIL isn't on.
Try removing the negative battery cable for a couple of minutes. That will clear out the adaptive memory for your driving style.
2006 Camry LE Special Edition
Old 05-11-2008, 12:21 PM   #3 (permalink)
What is MIL?
Ok, Just for example,
When I step on the gas 1/4 of the way, the car feels like it doesn't want to move or feels heavy/slow
When I step on another 1/4 of the way, the car totally jerks, revs and go.
It feels as if it a miss shift, or something is wrong with the clutch.
I am driving an Automatic btw, I4, 40k miles on it.
I will try to remove the battery wire.
Old 05-11-2008, 02:14 PM   #4 (permalink)
TRD VVTi's Avatar
Gen5
Originally Posted by FallOutBoyx530 View Post
What is MIL?
MIL = Malfunction Indicator Lamp (check engine light)
You are feeling your car downshift into a lower gear. The lower gear makes the engine RPM's increase. That's normal. Sometimes the cars adaptive memory seems to not blend well with the persons driving habits. I've seen this happen MANY times. Resetting the ECM works great if that's the problem.
Old 05-11-2008, 03:38 PM   #5 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
TRD is so full of knowledge....LoL
I did that a few days ago and it worked for me. I guess I gunned it a few times and the computer thought that is how I wanted to drive all the time.
It was wrong.
Computer: 0
Me: 1
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
Old 05-11-2008, 04:40 PM   #6 (permalink)
The Connoisseur
CharmCityES's Avatar
does it feel like a hesitation? you may be feeling an adverse sensation of the drive by wire (DBW) throttle, which uses a computer controlled throttle instead of a traditional throttle controlled cable....this system causes a lag time in between you hitting the throttle and the car responding, thus the feeling of hesitation and then a jerking in a surge of power....there is no cure for this, as its just how the car is
if in fact it has something to do with the car and your driving style, id disconnect the battery negative (-) terminal and let it sit for 10 minutes to reset the ECU, and then drive it and let the car relearn according to your driving style. youll be real suprised how effective simply resetting the ECU is and the problems it solves
The "Executive Sedan"
Old 05-11-2008, 05:36 PM   #7 (permalink)
View warpedrotor's Photo Gallery
Mine did that too when I first got it. It seems to be ok now, but I think it's a combination of the computer leaning the way I drive or me learning to drive with the delay in throttle response. Now I push on the gas just a bit until the engine responds then lay on more pedal to get going. Takes a bit of getting used to. I may also try resetting the ECU. I drove a Pontiac Vibe (Matrix) a while back and it seemed to do the same thing, I dunno if it has the same drive by wire system.
warpedrotor is offline   Reply With Quote
Old 05-12-2008, 05:37 PM   #8 (permalink)
Wow, you took the words right out of my mouth. This is exactly what's happening.
I have disconnected the negative battery already, and it seems to work for most of the time. Probably just my driving habits.
Also I remember when I bought the car new, it never did this until maybe 10k miles in? I hope this is normal for the car and abnormal for the driver.
Again, thanks for those who responded.
Old 05-18-2008, 03:10 PM   #9 (permalink)
ok, I think I know how to explain the issue now:
When I press on the gas, the clutch speed is faster than the wheel speed. I believe the clutch speed is faster than the tires, this when i gas from a stop, it takes a moment for the car to move and jolts when it does.
Is the solution the same as above by disconnecting the negative?
Old 05-18-2008, 04:32 PM   #10 (permalink)
TRD VVTi's Avatar
You have a manual transmission?
If so, it sounds like your clutch is slipping.
Old 05-18-2008, 05:37 PM   #11 (permalink)
One of his earlier posts states his car is automatic. It's really hard to get a handle on what't going on: if the transmission or torque converter is slipping or if the engine is not responding right away. I guess if the RPMs are coming up right away and the car isn't moving, it is a transmission issue, might be just low on oil.
If the RPMs aren't coming up when he hits the gas it's related to the what is decribed in the previous posts by CorCamrySE and others.
Old 05-18-2008, 06:36 PM   #12 (permalink)
2002 Camry XLE 2.4L
View pepperdanky's Photo Gallery
Not sure what causes this but I think I had the same thing happening to me before i seafoamed my car. Whenever I would apply pressure to the accelerator with the car at idle, it would have a jerky start as if the engine wasn't responding right away.
Edit: I had 130k miles on the car at the time.
pepperdanky is offline   Reply With Quote
Old 05-18-2008, 07:43 PM   #13 (permalink)
TRD VVTi's Avatar
Gen5
I see that in a seperate reply he states it's an auto.
That being said, his clutch can't be slipping. He also wouldn't have a clutch to begin with as he states that he does. Engine RPM's are always greater than wheel speed. The OP is trying to act like he knows things that he doesn't which is only making the problem harder to understand.
If there was any slipping, the MIL would come on with a code for a input/output speed variation (slipping) which isn't the case.
I'm wondering if the OP disconnected the battery as I suggested, or if he's just done it in the past. His posts aren't very decisive at all.
Apparently he just has a normal condition...
Old 05-18-2008, 07:58 PM   #14 (permalink)
Well, I've learned what an MIL is and another reason for it to illuminate, so this isn't a complete waste of time, but what is 'OP"? I'm thinking Ron Howard from Mayberry....
Old 05-18-2008, 08:09 PM   #15 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Original Poster or Original Post
