TRD Spring Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2008, 10:36 PM   #1 (permalink)
Blue Ribbon FTW!
fdexclpl's Avatar
View fdexclpl's Photo Gallery
TRD Spring Install
I installed my TRD springs today. It wasn't very hard to do. Anyone with some mechanical skills and the necessary tools should be able to do it.
I thought I would do a little write-up with pictures. I'll start with a list of tools and a few tips/suggestions/warnings.
Here are a few tips for you. A few days before you start the spring install spray all of the nuts and bolts with PB Blaster or some other penetrating lube. Some of the nuts were already rusted. You will need the hex keys for the stabilizer bar end links. They are a PITA to get off. The keys fit in the end of the threads on the end link ball joint. Then you use a wrench to remove the nut. you need four hands to put the rear struts back in. It is really tough to get the three studs to go back in the top mount. Then you have to hold the strut up while fiddling with the nut that you can't even see. Mark everything with tape and/or a marker. It makes it much easier when reassembling the struts.
This is a list of the tools you will need and the different size bolts/nuts and their locations.
1/2" breaker bar
1/2" drive ratchet with extensions
3/8" drive ratchet with extensions
metric sockets for both
jack and jack stands
compressor and impact gun (not necessary but it makes it easier)
hammer
screwdrivers
torque wrench
spring compressor (Autozone tool loan)
5mm and 6mm hex keys (these are a must)
Rear
10mm 12mm for brake line and speed sensor
19mm for top nut and lower strut bolts
12mm for side bolsters on seats
12mm for 3 nuts on top strut mount
14mm for sway bar end links
5mm hex key for end links
Front
22mm for lower strut bolts
19mm for top nut
14mm for 3 nuts on top strut mount
17mm for sway bar end links
6mm hex key for end links
Remove the rear seat bottom and unbolt the side bolsters of the rear seat back. I have an LE the SE and XLE have different rear seats.
This is the rear upper mount
Jack the rear of the car and place jack stands underneath
Remove the rear wheels
Remove the speed sensor bracket and the brake line bracket
Loosen but don't remove the top nut on the strut
Place a jack under the lower control arm
Remove the swaybar end link nut from the strut
Loosen the two bolts on the lower mount
Mark the stud and its position so it can be reinstalled in the same location
Remove the three nuts on the top mount
Remove the lower bolts and gently lower the jack and remove the strut
I marked each of the struts with tape so that I could line everthing up during reassembly
Compress the spring and remove the top nut
Compress the new spring and place it on the strut
Attach the top mount and tighten it down(don't forget the spacer)
Reverse the installation procedure
Raise the front of the car and place it on jack stands
Take off the wheels
Unclip the speed sensor wire plastic bracket from the strut
I didn't get any pics of the front strut but it is very different from the rear struts. The spring in the front is installed on an angle. It is a little harder to compress. Also the top mounts are multi piece and contain a bearing. Be sure to assemble this one correctly.
Here is a before and after
If I missed anything please feel free to PM me or chime in and I will update this post.
'07 Camry LE V6 - Blue Ribbon Metallic - 6-disc JBL - Moonroof
Someday I will list my mods here
Originally Posted by TRD VVTi View Post
I am a hater in one regard, I hate stupid.
fdexclpl is offline   Reply With Quote
The Following User Says Thank You to fdexclpl For This Useful Post:
fatngs (04-28-2011)
Old 05-14-2008, 10:39 PM   #2 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
looks like you got the black TRD springs... make sure you get an alignment
My Partial Partout!!!
Photo Album
Old 05-14-2008, 10:43 PM   #3 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076358
iTrader Score: 7 reviews
looks way better lowered, good job
2002 Camry SE V6 "Snow White"
Old 05-14-2008, 10:43 PM   #4 (permalink)
Blue Ribbon FTW!
fdexclpl's Avatar
Those were the old ones.
I only drove a mile or so just to make sure everything was ok. I'm getting an alignment tomorrow morning.
Old 05-14-2008, 10:55 PM   #5 (permalink)
2007 Camry SE V6
Gameroom cash: $132790
View thrawnis's Photo Gallery
Thanks for the DIY, I might do this when I get my springs... How long did the process take for all four wheels?
My Update Thread: http://www.toyotanation.com/forum/sh...d.php?t=319520
2007 Camry V6 SE | Blue Ribbon Metallic | UR Strut/Sway Bar | K&N SRI | Magnaflow mufflers | H&R Springs | TSW Cadwell 19x8 Wheels | 6000k HIDs | Reus Custom Sound System | Tinted Headlights | Smoked LED Taillights | More
thrawnis is online now   Reply With Quote
Old 05-14-2008, 11:17 PM   #6 (permalink)
Not-So-New TN User
Netforcer's Avatar
haha, i guess the last pic is the bottom of the strut and not the coils
Photo Album
Old 05-14-2008, 11:33 PM   #7 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
did you cut the bump stop?
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 05-15-2008, 12:12 AM   #8 (permalink)
phuangk's Avatar
View phuangk's Photo Gallery
Gen6
nice job!~
2008 Camry SE 4cyl
phuangk is offline   Reply With Quote
Old 05-15-2008, 01:06 AM   #9 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Major prop for taking the time to do the DIY with pictures! Well done.
Old 05-15-2008, 08:42 AM   #10 (permalink)
Blue Ribbon FTW!
fdexclpl's Avatar
About 4 hours. That includes bringing all of the tools out and putting them all back.
Old 05-15-2008, 08:42 AM   #11 (permalink)
Blue Ribbon FTW!
fdexclpl's Avatar
Nope
Old 05-15-2008, 09:38 AM   #12 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
+1
2006 Camry LE Special Edition
Old 05-15-2008, 11:41 AM   #13 (permalink)
The Connoisseur
CharmCityES's Avatar
nice DIY! im going to add this to my stickies!
car looks awesome! glad ya finally dropped it...love the wheels too!
The "Executive Sedan"
Old 05-15-2008, 01:54 PM   #14 (permalink)
Blue Ribbon FTW!
fdexclpl's Avatar
Thanks guys for the props. I'm glad that I had the time to take the pics and do the write-up.
Old 05-15-2008, 09:58 PM   #15 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
About the same with me, glad you finally got them installed!
I just got back from Arizona, so I haven't been around much. I can't wait to see them in person!
geoff5093 is offline   Reply With Quote
