Mod-Express HID Install, please help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-18-2008, 03:32 PM   #1 (permalink)
2007 Camry SE V6
Gameroom cash: $132790
View thrawnis's Photo Gallery
Unhappy Mod-Express HID Install, please help!
I just started installing the Mod-Express 4300k kit on my car. I covered the squirrel spotters with JB Weld and a piece of aluminum from a soda can, then folded down the metal flap.
When it came time to put the H11 bulb in, the 3 little notches aren't the correct size! The kit that I ordered is 100% an H11 kit, but 2 of the three tabs are a little too wide and will not fit into the "slots" in the headlight assembly. Would it be safe to file then down with sandpaper a little to make them fit? Or is there a better way to make this work?
My Update Thread: http://www.toyotanation.com/forum/sh...d.php?t=319520
2007 Camry V6 SE | Blue Ribbon Metallic | UR Strut/Sway Bar | K&N SRI | Magnaflow mufflers | H&R Springs | TSW Cadwell 19x8 Wheels | 6000k HIDs | Reus Custom Sound System | Tinted Headlights | Smoked LED Taillights | More
thrawnis is online now   Reply With Quote
Old 05-18-2008, 03:43 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
another quality kit..........
Old 05-18-2008, 03:44 PM   #3 (permalink)
View danorthface's Photo Gallery
sandpaper takes too long. Use a dremal. Or you can try nail clippers.. br creative
danorthface is offline   Reply With Quote
Old 05-18-2008, 03:49 PM   #4 (permalink)
No Mod can stop me
centennialman's Avatar
View centennialman's Photo Gallery
Isn't this the company that stated that they didn't manufacture their kits correctly with some bunk about how Camry H11's are "different" than other H11 bulbs (or something along those lines if I recall) ?
SE Every other trim
centennialman is offline   Reply With Quote
Old 05-18-2008, 03:52 PM   #5 (permalink)
it pays to floss
Trojan's Avatar
View Trojan's Photo Gallery
I have the same ones. I had mines installed at a local shop and they had to shave/grind it down for proper fitment.
Here's the thread where a couple of people did the same thing to get them to fit.
HID Mod express $110 shipped
07 Camry LE
http://www.cardomain.com/ride/2688832
08 WRX Sport Wagon Premium Edition
http://www.cardomain.com/ride/392672...sport-wagon-4d
Trojan is offline   Reply With Quote
Old 05-18-2008, 04:23 PM   #6 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
I would just take pilers and bend off the excess parts of the tab.
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
Old 05-18-2008, 04:44 PM   #7 (permalink)
2007 Camry SE V6
I just got a metal file at Lowe's. I think this should work a little better than sandpaper. My hands aren't the most steady so a dremel would probably not be the safest things for the bulb...
Thanks for the suggestions everyone, I will post the results of my install when I am done later tonight.
Old 05-18-2008, 09:01 PM   #8 (permalink)
2007 Camry SE V6
Ok, I filed down the 3 "tabs" on the bulb for both sides and the the bulbs went in pretty smoothly. Unfortunately, the bulbs were still a tight fit. I am not an expert in the area, but I would imagine that other cars that use H11 bulbs would have a similar problem but whatever...
I have a new problem that I need your help on. The instructions included in the Mod-Express kit are practically useless. Between the poor language and writing skills and the lack of H11 specific instructions, I am struggling to figure out how to utilize the relay and how to connect it to the battery. Please, does anyone have pictures of how the bulb connects to the ballast, how the ballast connects to the relay, and how the relay connects to the battery? I want to confirm that I have everything done properly.
It seems as though there are a lot of "extra" connections that don't go anywhere. For example, there are two small black and red wires with little metal connectors or something on the end that go nowhere. There is also an extra bulb connector on the bundle of cables that attaches to the bulb itself that I don't think connects to anything. Does this make sense?
Thanks again for everyone's help!
Old 05-18-2008, 09:08 PM   #9 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
there were a lot of users w/ this HID kit. Mod express said that they would fix this a couple of months ago. Seems like they didnt...
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 05-18-2008, 09:17 PM   #10 (permalink)
there are extra wires.. just cut them off.
Old 05-18-2008, 09:38 PM   #11 (permalink)
2007 Camry SE V6
After a bit of research I found some generic instructions on how to install the HIDs: http://www.mobilehid.com/support.htm . By the way, these instructions and pics are FAR better than the ones in the manual from Mod-Express!!!
Again, thanks for everyone's help. Once I know that everything I working properly, I will remove the extra connectors.
Old 05-19-2008, 01:56 AM   #12 (permalink)
2007 Camry SE V6
After reviewing the pics and instructions, everything seems to be connected the properly. Unfortunately, the headlights will not start up. The turn signals come on, but the HIDs do not light up. When I turn the headlight switch on, I hear a click noise that sounds like it came from the ballast but not sure.
I have checked every connection, disconnected and reconnected each connection to the battery, etc. Below are some pics of the wiring (sorry for the poor quality), the iPhone's camera sucks: http://www.flickr.com/photos/26729891@N06/
Can you guys tell me what I did anything wrong?
Old 05-19-2008, 02:04 AM   #13 (permalink)
Work Hard, Play Later
View LNGasMan's Photo Gallery
The click noise you hear is the relay activating. Check your polarity on the ballast power and ground connection. (i.e. if the power and ground is reversed on the ballast connection, it won't fire up) That's where I'd start. If you have a test light probe, that would be helpful for you to follow the power and ground through each connection of the relay harness to the ballast. From your other problems, it wouldn't surprise me if they wired it backwards somewhere. Everything else looks okay in the pictures from what I can tell.
Gotta love the high quality of HID kits...
2011 Camry SE - Magnetic Gray Metallic
2011 Rav4 - Black Forrest Pearl
LNGasMan is offline   Reply With Quote
Old 05-19-2008, 09:13 AM   #14 (permalink)
let me see your relay connection that connects to the stock harness. Make sure it's the right polarity and make sure the metal pins make contact
Old 05-19-2008, 09:19 AM   #15 (permalink)
2007 Camry SE V6
In the pic below, you can see kinda see the relay connecting to the car's headlight harness. The cable with white and black wires that is sitting between the battery and the jumble of red/black wires. Sorry, that's the best pic I have at the moment since I am at work right now.
