VSC/Traction Control after replacing tires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-18-2008, 08:46 PM   #1 (permalink)
View Slice's Photo Gallery
Woops. I miss read something in the manual.
That's All Folks!
2009 Toyota Camry SE V6 Black/Black
Leather, Navi, Spoiler, Moonroof, VSC w/ Traction Control
Slice is offline   Reply With Quote
Old 05-18-2008, 09:00 PM   #2 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
does not make any sense to me...and you are planing in April for the next winter? wow.
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 05-18-2008, 09:12 PM   #3 (permalink)
Well this will be the car I drive this winter season and just curious. Here is a photo I took of it:
Old 05-18-2008, 09:20 PM   #4 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Originally Posted by Slice View Post
I currently own a fully loaded 2009 Camry SE V6 and I was flipping through the manual and I noticed it said to contact your Toyota dealership when replacing tires because the new tires will some how not let the VSC/Traction Control function properly. I plan on switching out my tires with some studded snow tires, for this up coming winter.
Is there any truth to this?
Did you read the paragraph that you included in your second post? Where does it say to contact the dealer when replacing tires? It says that you should use the same brand and tread pattern and inflate properly for the system to work properly. That's hardly the same as instructing you to contact the dealer.
gdanaher is offline   Reply With Quote
Old 05-18-2008, 09:24 PM   #5 (permalink)
Take it easy... :-)
Tobeit's Avatar
That just states you should use the same size and type of tire all around and with proper dimensions etc etc. Has nothing to do with the tire change itself...and disclaimers to protect them if someone chooses awkward tire spec or suspension. Even with the TRD drop the VSC/TRAC works just fine and is under warranty, LE/SE/XLE come with different tires/rims and all work fine with the VSC. Don't worry.
