Painting Rs Grille - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2008, 04:38 PM   #1 (permalink)
View camry4lyfe02's Photo Gallery
Gen5 Painting Rs Grille
Hey guys! got my RS grille yesterday, but i wanted to repaint the chrome to my gun metal color, so it would look a lil cleaner, and may be a lil like that Sportivo grille. I have a question if anyone here actually repainted the grille themselves??? if yes then what did you use to take of the chrome, and what kind of paint, how much you used?
Thanks....
camry4lyfe02 is offline   Reply With Quote
Old 05-22-2008, 05:41 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Use sandpaper to sand off the chrome.
After the chrome is gone sand with a fine grit, spray on primer, and sand again.
I would recommend Dupli Color paint if you're going to spray paint it. Some paints require clear also to get the right color and luster, so be sure to check that.
2006 Camry LE Special Edition
Old 05-22-2008, 08:05 PM   #3 (permalink)
View james399's Photo Gallery
Thanks....
don't skimp on the prep work... after the primer is on and you sand, the surface has to be perfect, any imperfections, will show with paint...
as for the paint itself, you can use a rattle can or paint gun....
if you use automotive paint, there are 2 types...
1 step and 2 step... obviously the 2 step is with clear coat...
1 step is much cheaper....
i would try trd's suggestion with the rattle can, and if you don't like it you can always sand it off,
i painted my own body kit, but left my rs grille chrome... if you wanna try painting with a gun, let me know, i can give you some pointers...
good luck...
james399 is offline   Reply With Quote
Old 05-25-2008, 12:16 AM   #4 (permalink)
2006 Camry Base
View whiteboy's Photo Gallery
If you do it def let us see some pics, I was thinking about it when I got it but since my headlights are chrome inside I left it for the time being.
btw TRD VVTi, where did you pull your stainless mesh from, I was on a hunt last summer but couldn't find anything half decent around here locally, if it's not a trde secret ofc hehe
thanks, and good luck if you try it
whiteboy is offline   Reply With Quote
Old 05-25-2008, 06:07 AM   #5 (permalink)
TRD VVTi's Avatar
Gen5
I got my stainless mesh from Lockwood International in the UK. It wasn't cheap then, and because of the current value of the dollar, is even more expensive now.
Old 05-26-2008, 01:48 PM   #6 (permalink)
Gen 5 camry
Le0nell's Avatar
View Le0nell's Photo Gallery
I too recently bought an rs grill for my gen 5. My camry is black so i painted it black to match. My steps in painting this grill is
-strip chrome with sand paper
-Three coats of black paint (1-2 hours in between)
-two coats of clear coat
Is my first time using spray can so is not perfect
I also replaced the mesh that came with it cuz it looked like the diamond gaps are too big.
When i install in on my car ill get another pic of it.
Enjoy!
Le0nell is offline   Reply With Quote
