09 camry engine vibration
hi, all,
last time I mentioned I can feel vibration from the steering wheel on my new 09 camry. later, i noticed that the vibration may come from the engine. if I set the transmission at "Parking", and open the hood, I can see the engine is vibrating( some belts are running and the engine also vibrating, I can tell the difference), plus the thing on right of engine which is connected to it are also vibrating. the vibration is small magnitude, but it is there. the rest part under the hood like the radiator are not vibrating.
is this normal? because I notice the engine is also noisy on other camry when I test driving.
I ask because my old celica shakes a lot and the mechanic told me that one of motor mount are broken. but my camry is brand-new, 5 days old, the mount should not broken? and there should no broken gasket in the engine, either?
regards,
t.z.
