have them balenced, then check alignment
the issue could be that you have a bent wheel if you said theyre used...or they could be cheap wheels too, and sometimes cheap aftermarket wheels cause a vibration
Some wheels, no matter what you have done will never be right. I had a set of American Racing Nitros on my Ford Explorer Sport. I had every type of balancing and three alignments done and still had a shudder at high speeds. Sometimes changing tire brands helps but no always. Good Luck!
2007 Camry SE Titanium Metallic V6: Muth signal mirrors, 18" TSW Mondello wheels, Crimestopper alarm/remote starter.
I assumed they were balanced b/c they already have some weights added to the inside, but it may be possible it wasn't done properly.... ?
They are used but with very low mileage. The guy who bought made a mistake and bought them for his S2000. Obviously, the offset was wrong and they stuck out a good inch so he had to sell.
i sorta had the same experience when i got my new set of 19" hiros. went through tire rotation, balancing, alignment, made sure hub rings were installed, etc. vibration went away when they tried a totally new set of tires.
Have the balance checked. At that time they can check the wheels for runout, tires for runout, and for road force variation (if they have a quality balancer).
Alignment has NOTHING to do with vibrations/balance.
i feel this shake in my car right around 65MPH so basically same thing. they were NOT used and they were balanced when i got them, but it's weird cuz its barely noticable and it isn't on every road so i think it could just be that i notice the imperfections in the roads more.....
2005 Toyota Tundra Blue Steel Metallic (SR5® Access 4.7L i-Force V8 with VVT-i)
Hmm, maybe your right but then again i live in arizona where roads here is not exactly perfect..
When I went to Phoenix earlier this month the roads were in incredibly good condition (just not when wet). I'm used to up north where the winters, potholes, and ice make some pretty nasty bumps and ditches.
