Any guide for taking headlight a part - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2008, 09:15 AM   #1 (permalink)
Jeet's Avatar
View Jeet's Photo Gallery
Gen6 Any guide for taking headlight a part
I m planning to black house my headlights but don't know how to take the headlights apart. I've been searching around the forum and i found a guide for taking apart the headlights for a GEN 5, i was wondering if the GEN 6 is the same process...or is there a DIY guide already for a GEN 6 and missed it when searching on the forums. Thanks
2007 Camry | 3.5L 2GR-FE | SE |
1997 Corolla | 1.8L 7A-FE | DX |
Jeet is offline   Reply With Quote
Old 06-01-2008, 09:30 AM   #2 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Here is a detailed DIY guide on taking apart the headlights: DIY: taking apart headlights (56k: 20 low resolution pictures. you decide)
And heres a guide I made for the Gen 6, mainly for painting them though: My turn for blacked out headlights!
geoff5093 is offline   Reply With Quote
Old 06-01-2008, 10:11 AM   #3 (permalink)
another_person
View cdtran's Photo Gallery
its the same basic process. once you have the headlight off, decide if you're going to use a heat gun or an oven. Either way, make sure you remove the screws before you start. Just use the heating instructions from the other thread. Everything is the same.
cdtran is offline   Reply With Quote
Old 06-01-2008, 11:12 AM   #4 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
BE VERY CAREFUL WHEN BAKING. DO NOT RUSH IT. It is better to wait longer than to have to wait even LONGER and having to get a replacement one.
When i did my honda accord i went to 350F for about 3-5 mins checking ever 2-3 mins. This worked well for me but make sure you are always checking on it. Ive seen many DIY tutorials with different temps and time, in the end its up to you so make sure you dont just slap it in for X amount of time because a thread said it.
CamrySExxx is offline   Reply With Quote
Old 06-01-2008, 06:54 PM   #5 (permalink)
Jeet's Avatar
Those were the two DIY guide that i found on the site, thought there might have been more then i missed out on, Thanks for all your help guys!!
Old 06-01-2008, 07:28 PM   #6 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
Let us know how it worked out for you.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
Old 04-15-2009, 09:43 AM   #7 (permalink)
View Prettyboitt87's Photo Gallery
i was wondering what kind of black paint did u guys used? the dupli black enamel one or the flat black and some clear gloss afterwards.
Prettyboitt87 is offline   Reply With Quote
Old 04-15-2009, 09:53 AM   #8 (permalink)
high heat low gloss.
Old 04-15-2009, 10:16 AM   #9 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
I just did mine a couple of days ago. I should have done a DIY for gen6.
oven at around 250F, Make sure you take off all the screws and the black rubber seals. There is a little plastic cover on the corner that blocks a vent make sure you take that off too so that it doesn't melt because it's really soft plastic. I would say leave it in the oven for 10 min but you have to check it all the time. When you think it's hot enough, take it out and start prying and pulling (it's not easy) don't rush it thought. Pull and let the sealant separate and then pull more. if you think it wont go anymore, put it back in the oven for about 2 min and start prying and pulling more. the rest is easy. I did 2 light coats of plastic primer and 5 coats of rust-olium engine enamel gloss black heat resistant.
To put it back together put it back in the oven with the lens on, leave it in for about 5 min take it out and push in as much as you can and try to get the screws in as fast as you can to pull it together and seal it. I put sealant over the whole thing too before i put them back in the car.
If you need more info, just PM me
Redline_Me is offline   Reply With Quote
Old 04-15-2009, 10:30 AM   #10 (permalink)
The darker the better
TJHammer's Avatar
View TJHammer's Photo Gallery
Just did mine, basically 95% same process involved as people have stated.
Dude, if you have the time, give yourself 2 days for the deal, so you can take your UNSTRESSED/NON-RUSHED time (between baking...careful removal...paint...paint...paint, drying time, silicone sealing, etc)- Before you know it, hours have passed
TJHammer is offline   Reply With Quote
Old 04-15-2009, 10:40 AM   #11 (permalink)
yep took me 2 days for everything. Whatever you do..Don't rush any part of the process.
Old 04-15-2009, 11:48 AM   #12 (permalink)
TJHammer's Avatar
Or work from 830 am till 1am like some psychos
Old 04-15-2009, 05:29 PM   #13 (permalink)
mine went form 4pm to 11pm and then from 11am to 3:30 pm. but i was installing fogs and grille too while the sealant was drying a little bit.
Old 04-17-2009, 12:20 AM   #14 (permalink)
& JustAnotherCamry
View JustAnotherAsian's Photo Gallery
geoff already posted my diy.
i'd just like to add... be patient and clear out a whole day for this. low temps, in-n-out of the oven multiple times, and good sealing + extra sealant is the key.
btw, i used atv black silicone. r16 if i remember correctly.
JustAnotherAsian is offline   Reply With Quote
Old 04-17-2009, 07:28 AM   #15 (permalink)
TJHammer's Avatar
Exactly, patience is key, because oven strengths vary. My oven is fairly new and pretty strong, so I started at 200 for 10 minutes as a starter and got no give in the glue. Restarted process at 250, preheated, then turn it off insert headlight for 10 minutes and it was perfect to handle and take apart with the glue loose enough. Better off starting low, and losing some time rather than a headlight lol
I used window and glass silicone sealer, there seem to be multiple options in that regard.
* I don't know about you guys, but this is a drag-on mod bec of the time'n'patience, but seriously makes ya proud when its done and you admire the work
