? about speakers in the dash(non jbl) pics inside. 56K friendly - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2008, 02:17 PM   #1 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
Gen6 ? about speakers in the dash(non jbl) pics inside. 56K friendly
The sound system in this car isn't too bad, but the high end is way too tiny, and most of the high end comes out of the dash speakers. Would anyone have any recommendation on what to replace them with? I was thinking maybe the ones from a jbl? Also: I took the speaker cover off, and looked at them, but theres a wiring harness hooked up to them, and i dont know what its there for? Here are pics
Heres the harnes im refering to
this is the actual speaker
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 06-01-2008, 08:37 PM   #2 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
wiring harness is probably for a cross over or something like that?
CamrySExxx is offline   Reply With Quote
Old 06-01-2008, 09:02 PM   #3 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
well, theres only one way to find out.. and thats to unplug it and see what happens. lol
Old 06-01-2008, 10:45 PM   #4 (permalink)
View sundarpn's Photo Gallery
I have an 02 XLE and the felt the same.
I got a set of tweeters with high sensitvity (think it was 102 db) and connected them in parallel to the dash jbl speakers. The tweeters were small and came with a dash mount and were under 18 bucks shipped on ebay.
The cross over was inside the rubber covering on the wires to the dash speaker. Since the tweeter I got had a built in cross over, I connected it before the cross over of the dash speaker. THe results, I love it!. Pretty simple The treble is just great. I have to keep it at two or three max other wise the highs are way too high.
thanks.
sundarpn is offline   Reply With Quote
Old 06-02-2008, 12:11 AM   #5 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
The wiring harness is for the signal to the tweeters. The speakers can't magically receive a signal from the radio!
My suggestion is to replace the front speakers completely and put a good 6.5 or 6.75 component set in the door. Forget about the tweeters in the dash. You can just disconnect them and leave them there or remove them completely.
2007 Camry 2.4L 5M
Old 06-02-2008, 12:12 AM   #6 (permalink)
If you unhook the wires, then the speaker doesn't work. And neither will the door speaker because the tweeter and door speaker is connected in parallel but using some circuit at the tweeter as a bridge. You can use a jumper wire to bypass the tweeter.
2007 Camry 2.4L 5M
Old 06-02-2008, 12:12 AM   #7 (permalink)
Stock speakers don't have crossovers. There's only a filter capacitor for the tweeter.
2007 Camry 2.4L 5M
Old 06-02-2008, 06:26 AM   #8 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen6
I would put a full system in it, but its leased and what I change needs to be undoable
Old 06-02-2008, 02:25 PM   #9 (permalink)
So then keep the stock speakers and put them back before you return the car.
2007 Camry 2.4L 5M
Old 06-02-2008, 08:25 PM   #10 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen6
would high end speakers sound good on a stock head unit though?
Old 06-03-2008, 02:54 PM   #11 (permalink)
nj0ywatch1np0rn's Avatar
View nj0ywatch1np0rn's Photo Gallery
is the factory system 4oh or 2ohm?
2007 Camry SE
nj0ywatch1np0rn is offline   Reply With Quote
Old 06-03-2008, 02:58 PM   #12 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Depends on which system you're talking about..........
Old 06-03-2008, 03:06 PM   #13 (permalink)
non JBL
2007 Camry SE
Old 06-03-2008, 05:36 PM   #14 (permalink)
How high end are you talking about? My components cost about $300ish but I got them intending to amp them. You could probably get a decent set for $200ish that will run fine off the stock head unit. I wouldn't bother with the back ones though.
I'm sure there are some people who have put components on their stock stereo, but I don't know who.
You do have a point though, there is a chance that aftermarket speakers might sound worse since you cannot defeat the equalizer settings in the HU that compensate for the (lower) quality of the speakers.
non JBL
4 ohms
2007 Camry 2.4L 5M
