Originally Posted by TTM77
Care to give more info?
I agree that it's not relate to oil change. How far can the car go with the oil drain empty? (considering he forgot to put in the oil or the screw is gone and leaks all the new oil he put in) But of cause this solution is not likely since his car is not smoking yet.
Oil has nothing to do with shifting of the car or any increase or decrease of power that can be detected by simply driving the car. The only thing that I can think of is if the engine is actually noisier and the knock sensor is picking it up causing the ECM to retard the timing. That isn't likely, however. To check that, you would actually have to access the ECM and check the knock counts.
How far can the car go without oil? It really depends. I've seen cars go for 30 miles without oil and have seen cars that locked up after just seconds of running. For some reason Toyotas seem to fair well though. I've seen an Avalon run for over a half hour without oil and then still keep running for over 15 minutes after running at 4,000 RPM's (rough estimate from memory).
If there wasn't any oil in the car the oil light would be on anyways, as there wouldn't be any oil pressure.
