V6: Mobil 1 0W-30? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2008, 08:36 PM   #1 (permalink)
2008 SE V6
thoots's Avatar
View thoots's Photo Gallery
V6: Mobil 1 0W-30?
Well, I ran into this stuff at Wal-Mart the other day:
Mobil 1 0W-30 Advanced Fuel Economy synthetic oil.
http://www.mobil.com/USA-English/Mot...l_1_0W-30.aspx
Supposedly absolutely OK to use in applications that specify 5W-30, like the Gen 6 V6. I bought some, and I'll use it for my next oil change, about a month from now.
But, what do you think? Does it sound good to you? I'm all for getting a little better fuel economy, if this might actually do the trick.
thoots
thoots is offline   Reply With Quote
Old 06-02-2008, 08:58 PM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
You aren't likely to notice much change in mileage but if used consistently, the engine will thank you by living longer.
gdanaher is offline   Reply With Quote
Old 06-02-2008, 10:20 PM   #3 (permalink)
I'd Buy Another One
squeakyg's Avatar
View squeakyg's Photo Gallery
I wouldn't buy it strictly for a gas mileage difference. I switched over at 500 miles and there was no noticable difference. The switch is a pretty expensive one and is like spending money to save money, especially if you are changing oil frequently.
I switched over to see the long term affect on the engine. I have a buddy who has my same year and it will be interesting to see how the different engines react to different oils. If I find not much difference over a long period of time, then I will probably never use it again. It is expensive.
Camry V6
squeakyg is offline   Reply With Quote
Old 06-03-2008, 12:34 PM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
It won't change anything. The warm weight is still the same, it's just pumps better when cold.
2006 Camry LE Special Edition
Old 06-03-2008, 02:29 PM   #5 (permalink)
Joined the dark side. :D
Gameroom cash: $656091
View workerant's Photo Gallery
I use the Extended Performance since I don't like changing oil so often.
workerant is offline   Reply With Quote
Old 06-03-2008, 02:32 PM   #6 (permalink)
2008 SE V6
thoots's Avatar
Well, no, I'm not using it just in hopes of getting slightly better gas mileage. I've been using Mobil 1 synthetic for years, so this would just be a slight change from Mobil 1 5W-30 to Mobil 1 0W-30.
It's really the "cold starting" end of things that I'm concerned about, since I have a commute so short that I actually drive home for lunch. So, that's four two-mile trips per weekday. And I sure like the idea of doing it with "0W" oil than "5W" oil.
thoots
Old 06-03-2008, 03:15 PM   #7 (permalink)
TRD VVTi's Avatar
That's exactly where the advantage is.
