Quick Rim Offset question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2008, 11:16 AM   #1 (permalink)
wetherburner's Avatar
View wetherburner's Photo Gallery
Hi guys,
I just bought 225-45-18 Yokohama Advan Sport tires and am in the process of finalizing my rims.
I'm getting 18x8's and wondering if a +35 ET will be OK. I have a choice of 35 or 45 - and according to a rim/tire calculator site, the +35 ET will stick out 15mm (0.6") further than OEM.
Is the 35ET OK? Although I suspect it is and is the better choice, I'm just looking for affirmation.
Thanks.
BTW, I'm getting the Konig Runaways in Hyper Gun Metal... Will post pics when it's done shortly.
wetherburner is offline   Reply With Quote
Old 06-03-2008, 11:19 AM   #2 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Originally Posted by wetherburner View Post
Hi guys,
Thanks.
Go for the +35 offset. That is exactly what I have for my front wheels and tires. 18x8 +35 offset with 225-45-18. The +45 offset is tucked-in too much.
Old 06-03-2008, 11:40 AM   #3 (permalink)
it is what it is
akira751's Avatar
View akira751's Photo Gallery
Gen6
+1
07 Camry SE V6, Nav Mag Grey,18" Nex-0 gun metal, Trd Springs,K&N Typhoon Intake
http://www.cardomain.com/ride/2475669
akira751 is offline   Reply With Quote
Old 06-03-2008, 12:50 PM   #4 (permalink)
Support Authenticity!!!
moky-tron's Avatar
View moky-tron's Photo Gallery
is there +30 offset avail? i would do that if it was avail, otherwise +35 is good
moky-tron is offline   Reply With Quote
Old 06-03-2008, 01:06 PM   #5 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
...probably not, but 5mm spacers are .
Tobeit is offline   Reply With Quote
Old 06-03-2008, 03:25 PM   #6 (permalink)
Thanks guys - sounds like +35 is the way to go.
I'm being told I need a 73.1-60.1 hubring. Maybe a NOOB question, but what is this and what does it accomplish?
Old 06-03-2008, 03:37 PM   #7 (permalink)
Here and there...
60.1 is the inner diameter (Toyota/Lexus hub bore all have 60.1)
73.1 is the outter diameter (In this case, your wheels have center bore of 73.1)
The hub centric rings primary job is to fill the gap between your aftermarket wheels and the car's wheel hub bore. 73.1 - 60.1 = 13.0 mm is the gap.
Why such gap? Because each vehichle manufacture wheel hub bore are difference, hence all Toyota/Lexus wheels are 60.1 mm so it will match the car hub bore exactly. Aftermarket wheels wants to sell their wheels to a wide market of car makers so they make a universal hub bore to fit as many vehicle as possible. That is why you need a hub centric rings.
Old 06-03-2008, 03:50 PM   #8 (permalink)
Great explanation - thanks.
So I presume I would simply remove the rings when putting my stock 17's back on the vehicle for winter driving...
Old 06-03-2008, 03:51 PM   #9 (permalink)
Take it easy... :-)
Tobeit's Avatar
...keep them pressed into your wheel during that time. Often they fit snug and if together with your wheel don't get lost.
Old 06-03-2008, 04:34 PM   #10 (permalink)
Here and there...
Correct. The hub centric ring is now part of your aftermarket rims.
When I put my rims away for storage, I use a little black tape to make sure the rings stay inside the wheel hub bore.
Old 06-03-2008, 06:52 PM   #11 (permalink)
camrydanny's Avatar
View camrydanny's Photo Gallery
hi
also, i can get some nice is350 18" with 45 and 50 offset, does anybody have those as is on thier 2007 camrys? or do i need spacers?
the tires would be 225/45/18
thanks
pics would be great, sorry to hijack thread
camrydanny is offline   Reply With Quote
Old 06-03-2008, 06:58 PM   #12 (permalink)
Here and there...
Originally Posted by camrydanny View Post
hi
thanks
I just sold those rims last month.
The IS250/350 are 18x8 +45 Front and 18x8.5 +50mm According to Eddiefromcali, he used a 3mm spacer in the rear because it rubs a little bit but that because he has 255/40/18. If you put on 225/45/18 the front would look good and the rear would be a little stretch but the good thing is you won't rub because of the 225 is not as wide as the 255.
Bottomline, if you run 225/45/18 you will not need any spacer.
Old 06-03-2008, 08:17 PM   #13 (permalink)
instant noodle FTW
INDOMI's Avatar
View INDOMI's Photo Gallery
yeah like what others have said +35 is fine, mine is 20x8 +35 at the front and its not even flush with the fenders
INDOMI is offline   Reply With Quote
