Need advice...warped rotors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2008, 11:33 PM   #1 (permalink)
Eyekutr's Avatar
View Eyekutr's Photo Gallery
I have an 07 camry LE my dad drives....23k miles. He's out of town and I am driving the car and noticed he has warped rotors, pads are plenty still, at least 1/2 pad left....I will take it in.....question....I know dealer SHOULD technically turn them for free...but should I insist on a new set under warranty....is there any grounds or reason for this? Thanks in advance...
11 Sienna XLE / 07 Camry / 06 GS300 / Retired from service 04 GX470
Eyekutr is offline   Reply With Quote
Old 06-03-2008, 11:45 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
You have no grounds for replacement as they should be plenty thick. Have the dealer resurface them.
2006 Camry LE Special Edition
Old 06-04-2008, 12:06 AM   #3 (permalink)
Eyekutr's Avatar
Thanks for your input...rotors felt pretty smooth to the touch, but symptoms are there so it must be mildly warped....maybe the air wrench they use at the tire store (vs hand torque) had something to do with it....
Old 06-04-2008, 12:14 AM   #4 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
The dealer just resurfaced all 4 of my rotors last month. They also threw in 4 new brake pads as a goodwill ofcourse.
Old 06-04-2008, 12:18 AM   #5 (permalink)
TRD VVTi's Avatar
That's usually the cause. Don't say that to the dealer though.
Old 06-04-2008, 02:43 PM   #6 (permalink)
I callz it like i seez it
View ScrooYoo's Photo Gallery
if you are using high quality brake pads i would just replace the rotors with premium slotted/driled rotors. if you use high quality semi-metallic or ceramic brake pads on low quality rotors they will warp frequently. I had a problem with my rotors warping every few weeks until I got rotors that were as good as my pads.
if you are just using regular old brake pads then resurfacing is probably the best option though.
ScrooYoo is offline   Reply With Quote
Old 06-04-2008, 03:13 PM   #7 (permalink)
Eyekutr's Avatar
I am using highest quality TMC parts LOL .....it is whatever they slap on there at kentucky man....this is a stock camry we are talking about
Old 06-04-2008, 03:52 PM   #8 (permalink)
View wilsonca's Photo Gallery
Had the same problem at 25k. The dealer turned them under under warranty.
wilsonca is offline   Reply With Quote
Old 06-04-2008, 06:00 PM   #9 (permalink)
View khanh007's Photo Gallery
Gen6
I had the same problem, from the same cause, at almost the same mileage (27K)...
I went to the dealer to see if they would replace rather than turn the rotors.
They said that they would only turn the rotors if needed.
I prefer to replace them, since they are cheap enough.
I bought Raybestos Advanced Technology rotors from rockauto.com for $39.00 each, swapped them out for the old ones.
Now my 07 SE brakes as if it were new.
I actually felt the warpage in the rotors (only on one).
I swapped both rotors out to be sure that I got rid of the nasty wheel shake at high speed braking.
It even got rid of an annoying slight squeak I was getting when applying the brakes at very slow speeds (like when you are driving through a drive-through at a fast food joint). Although, I suspect this is because I lubed the cr@p out of the brake pad shims and pad seating mounts...LoL
Regards,
Kahnh
khanh007 is offline   Reply With Quote
Old 06-04-2008, 06:06 PM   #10 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $150432
View Yazovets's Photo Gallery
The dealer does NOT owe you a new set since this is a wear and tear item.
My front rotors had warped a couple of months ago. I had my mechanic re-surface them and the vibration has since disappeared.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 06-04-2008, 07:44 PM   #11 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
Warpage are very common on hilly, mountain areas.
My Uncle who lives in Ranco cucamonga always have this problem on his Civic.
Nad1370 is offline   Reply With Quote
Old 06-04-2008, 07:49 PM   #12 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
What have the type of streets you are on to do with the idea of warped rotors...just because your uncle needs to brake down the hill does not mean the rotors warp more likely out of a sudden .
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 06-04-2008, 08:17 PM   #13 (permalink)
Nad1370's Avatar
Toilbet,
I didn't say this happened to him one time after braking.
He drives to LA twice a week and elevation changes quite a bit.
Doesn't also help when your doing 75-80mph on the freeway and donwhill comes up and mph jumps to 90.
Now he has to slow down gradually and not slam on the brakes or he'll get rear ended.
How much heat do you think gets generated on the brakes.
I'm not saying he gets his rotors turned every month. More like once a year where it gets annoying.
Old 06-04-2008, 10:10 PM   #14 (permalink)
View warpedrotor's Photo Gallery
I always seem to have them.
warpedrotor is offline   Reply With Quote
Old 06-04-2008, 10:15 PM   #15 (permalink)
Cathode Protector
View cosism's Photo Gallery
OH no! That is where I live.... If you are talking about R.C. in Socal.
07' SE V6, TSX retro w/ color mod, Chrome 18" GS430 wheels, led bulb swaps, tinted windows, K&N drop-in, Sirius, door moldings(FTMFW!!!!). 2 Britax seats too!
cosism is offline   Reply With Quote
