smoke during start up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2008, 12:06 PM   #1 (permalink)
View tvanderster's Photo Gallery
Hi all,
I have a 2002 camry 4 cylinder XLE- great shape 165000 km.
I recently noticed that during start up, there is a small plume of smoke (oil burning??). I only see this during start up in the morning when the car has been sitting overnight. I don't notice this during the day.
There are no external leaks.
Could this be that the pcv valve needs to be changed? If so, how do you do it?
Or was there too much oil in the engine?
Appreciate your help?
thanks
Tim
tvanderster is offline   Reply With Quote
Old 06-06-2008, 12:25 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Most likely cause is bad Valve seals, Very common issue
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 06-06-2008, 12:28 PM   #3 (permalink)
so most likely too costly to fix?
Old 06-06-2008, 12:34 PM   #4 (permalink)
Hi
so would it cost too much to fix? Should I just leave it or will it get worse.
There is 0 loss of power.
Old 06-06-2008, 12:45 PM   #5 (permalink)
JSM1284's Avatar
Its a typical problem. Most of them do it. It dos not need immediate attention. Just make sure you keep the oil at recommended level.
2005 Lexus ES330
Old 06-06-2008, 12:57 PM   #6 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
As stated, if you are not seeing any noticeable drop on the dip stick then the engine isn't using much oil. Valve stem leakage is nothing to be concerned about until it starts burning more during operation. By the time it's time to really worry, it's also time for a valve job or worse and then you fix it. If you do a lot of high speed driving and the oil level drops quickly, then you might have a PVC issue, but otherwise not likely. Pull it and spray some carb cleaner in it if you are inclined.
gdanaher is offline   Reply With Quote
Old 06-06-2008, 12:58 PM   #7 (permalink)
Hi
Thank you
cheers
Old 06-06-2008, 01:04 PM   #8 (permalink)
Hi many Thanks
will probably just leave it.. only use car to jump around the city (no long distance)
just hope that this wont cause problems passing the emissions test every two years as we have to do this in Ontario
Old 06-06-2008, 01:46 PM   #9 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
As stated above, the valve seals are starting to leak. I wouldn't fix it unless you start using a lot of oil.
Valve stem seals usually wear much quicker in cars that aren't maintained properly.
2006 Camry LE Special Edition
Old 06-09-2008, 02:04 PM   #10 (permalink)
Banned
View TRD_EarBanger's Photo Gallery
Just in case you were thinking about it, dont try the old trick of banana in the tailpipe its dangerous. It will slow down the appearance of the smoke thats all]
NO! In the tailipipe
TRD_EarBanger is offline   Reply With Quote
