I think my trans flared on my 2008 LE V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-14-2008, 07:08 PM   #1 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $400224
View BlackCamSe's Photo Gallery
Gen6 I think my trans flared on my 2008 LE V6
I was driving on the highway about 35 mph after some bonehead decided to cut off the guy in front of me, so we both had to slam our breaks. SO i through it into sequential shift (2nd gear). When i shifted it from 2nd to third at about 5500 RPM's. It went up to about 6000 then shifted. It felt like the trans disengaged then shifted. If I'm not mistaken, thats the flare. Later on my way home I'm going to try and manipulate it to do it again. I'm hoping it was just my head, or a freak thing. It has 5000 miles on it.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 06-14-2008, 07:30 PM   #2 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $133432
View Yazovets's Photo Gallery
Yes, that's a mild flare.
In terms of the 2-3 shift flare, it's easiest if you were accelerating hard in 2nd. When you reach 3500 or 4000rpm, take your foot off the gas pedal. At the same time, shift up to 3rd.
Leave a split second for the RPMs to go down to like 3000rpm, and then give gas. This should result in a massive 1000rpm - 1500rpm flare before the engine revs down and the tranny catches.
Keep an eye out for a 3-4 flare as well. I just got a new transmission installed because mine completely died. Claim whatever you can under warranty. My new tranny no longer flares.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 06-14-2008, 07:54 PM   #3 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen6
well, if mine doesn't to it too often, or badly. Ill just leave it. I'm going to try what you just said to see if i can get it to do it. If it does it to that extent, ill go to the dealer
Old 06-14-2008, 08:00 PM   #4 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Keep an eye out! When I bought my car brand new, it only did the 3-4 shift flare and it wasn't very severe (500-800rpm). Later on, it stopped doing this, but I developed the 2-3 flare. At first it was a 1000rpm flare which happened frequently. Later it started happening so frequently that I could reproduce it almost every time on demand with up to 1500rpm! And the 3-4 flare returned from time to time. Also I developed a rough 5-4 downshift.
Old 06-14-2008, 08:11 PM   #5 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen6
wow, you probably weren't surprised when it died huh? Good luck with the new tranny. And thanks for the heads up
Old 06-16-2008, 10:42 AM   #6 (permalink)
View yangt0720's Photo Gallery
Question about these transmission flares. Do these flares occur while in automatic drive mode? or while in sequential shift mode? I hardly use the sequential shift mode so not sure if my tranny flares or not. It seems fine in automatic drive mode though.
yangt0720 is offline   Reply With Quote
Old 06-16-2008, 11:24 AM   #7 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
They occur in both, but moreso in S mode (manual mode). Thanks, Camralon!
