2003 XLE Alarm System Malfunctioning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-14-2008, 07:23 PM   #1 (permalink)
View wallycurmudgeon's Photo Gallery
Gen5 2003 XLE Alarm System Malfunctioning
I have a 2003 xle with factory installed alarm system. When parked, out-of-the-blue, the alarm starts to sound. No one is around. Took it to the dealer but they couldn't replicate the problem. Any thoughts?
wallycurmudgeon is offline   Reply With Quote
Old 06-15-2008, 03:52 PM   #2 (permalink)
Dominican Republic
Dj-torn's Avatar
View Dj-torn's Photo Gallery
Your might have a bad battery, or something in the vehicle is draining the battery and that small current draw is causing the alarm to be set off.
1. Check to see if you have a drain on your battery when the vehicle is locked, should not be more than 30milliAmps.
2. Check to see if your altanator is charging.
3. Check to see if you battery is holding a charge.
Stock 2002 Camry LE: 2AZ-FE: VVT-i
Dj-torn is offline   Reply With Quote
