Sway bar link bushings worn out? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2008, 11:22 AM   #1 (permalink)
View alannj's Photo Gallery
Gen5 Sway bar link bushings worn out?
I have a 2002 V6 with 23K miles (father in law's old car) with the notiorious front end "clonk" noise when going over bumps at low speeds (not high speeds).
I'm pretty sure the problem is the sway bar bushings but I would like to eliminate the links as a possibility. Both the top and bottom sway bar link bushings seem tight, swivel nicely and have no play.
I would appreciate a description of what they look and feel like when they are worn out.
Thanks.
Alan
alannj is offline   Reply With Quote
Old 06-17-2008, 01:04 PM   #2 (permalink)
View toyomoho's Photo Gallery
Can be impossible to tell by looking at the sway bar bushings if good or bad even if removed. Wrap Teflon around the bar to take up the wear. The bushings should be cheap enough to just replace.
Can also be the upper strut mounts
Old 06-17-2008, 04:10 PM   #3 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
I had this problem for exactly two days. And it was only in the first few miles of my first drive of the day. Since then, the problem hasn't come back. Not sure what it was so if it comes back I guess I'll deal with it then.
'05 2AZ-FE @ 40K miles | '95 1MZ-FE @ 87K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 06-17-2008, 05:13 PM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Disconnect the sway bar links to see if the noise goes away. If it does, you know that's the problem.
2006 Camry LE Special Edition
Old 06-17-2008, 05:21 PM   #5 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
You'll know the links or the bushings are the problem.
Old 06-17-2008, 05:25 PM   #6 (permalink)
TRD VVTi's Avatar
Gen5
Maybe, but I've never heard bushings rattle yet.
Old 06-17-2008, 05:35 PM   #7 (permalink)
'07 XLE
Gen6
But they will "clonk" as the OP originally said.
