Code P0420 - Cuased by SeaFoam? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2008, 02:24 PM   #1 (permalink)
View rbarton's Photo Gallery
Please Delete
rbarton is offline   Reply With Quote
Old 06-17-2008, 02:51 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $172825
View JSM1284's Photo Gallery
P0420 - Catalyst System Efficiency Below Threshold (BANK1)
CIRCUIT DESCRIPTION
DTC Detection Condition
The ECM observes the waveform of the heated oxygen sensor located behind the catalyst to determine whether the catalyst performance has deteriorated.
If the catalyst functions normally, the waveform of the heated oxygen sensor located behind the catalyst switches back and forth between rich and lean much more slowly.
When the waveform of the heated oxygen sensor located behind the catalyst alternates flutteringly between rich and lean, it indicates the catalyst performance has deteriorated.
CONFIRMATION ENGINE RACING PATTERN
  1. Connect the OBD II scan tool or hand-held tester to the DLC3.
  2. Start the engine and warm it up with all the accessories switched OFF until the water temperature is stable.
  3. Race the engine at 2,500-3,000 rpm for about 3 minutes .
  4. When racing the engine at 3,000 rpm for 2 seconds and 2,000 rpm for 2 seconds alternately, check the waveform of the heated oxygen sensor.
Step 1 - 2
Step 3 - 4
INSPECTION PROCEDURE
HINT: Read freeze frame data using the hand-held tester or OBD II scan tool, as freeze frame data records the engine conditions when the malfunction is detected. When troubleshooting, it is useful for determining whether the vehicle was running or stopped, the engine was warmed up or not, the air-fuel ratio was lean or rich, etc. at the time of the malfunction.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
