Steering Wheel Making Noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2008, 08:34 AM   #1 (permalink)
View MechanicalMan64's Photo Gallery
Gen5 Steering Wheel Making Noise
Hey everyone,
For the past 3-4months my steering wheel have been making a lot of squeeky noise when i turn it (doesn't matter whether i turn left or right it makes a loud squeeky noise- sounds like twisting the wires?).
I drive a 2003 Toyota Camry LE V6 and it's got a auto-remote starter on it.
Can someone let me know how i can get rid of this noise? (lubricate it at which spot? etc...)
Apparently, the colder the car gets, the louder the noise. When my car is like totally warmed up (been driving for like half a day, the noise is not that big but there are still slight noises when i turn my steering wheel)
THanks! Greatly appreciated.
MechanicalMan64 is offline   Reply With Quote
Old 06-18-2008, 08:39 AM   #2 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
i believe the steering shaft has to be lubricated. there is a TSB out there for that, search for "intermediate steering shaft TSB"
MrSo0h0o is offline   Reply With Quote
Old 06-18-2008, 09:11 AM   #3 (permalink)
do they sell these at the dealers do you know?
Old 06-18-2008, 09:22 AM   #4 (permalink)
MrSo0h0o's Avatar
sell what? the intermediate steering shaft? if you have the TSB applied, you dont have to pay a penny.
Old 06-18-2008, 09:51 AM   #5 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
You just have to lube the boot at the base of the column where the steering shaft passes through it.
Read the "Newbies read before posting" sticky at the top of the forum. This has only been covered five hundred fukking million times...
2006 Camry LE Special Edition
Old 06-18-2008, 09:52 AM   #6 (permalink)
2002 Camry XLE 2.4L
View pepperdanky's Photo Gallery
TSB = Technical Service Bulletin, it's not a part to fix your problem.
pepperdanky is offline   Reply With Quote
Old 06-18-2008, 10:01 AM   #7 (permalink)
where exactly do i apply the lube? sorry, i don't know much about cars? pics will be great! thanks.
Old 06-18-2008, 11:10 AM   #8 (permalink)
2002 Camry XLE 2.4L
Look to the left of your brake pedal, you can see where the steering column goes through the firewall. Spray the rubber boot that the column goes into.
Old 06-20-2008, 11:49 AM   #9 (permalink)
TRD VVTi's Avatar
Grease works better than spray lubes.
Old 06-20-2008, 01:38 PM   #10 (permalink)
i just sprayed it, but doesn't seem to fix the problem? still squeaking....
Old 06-20-2008, 02:52 PM   #11 (permalink)
TRD VVTi's Avatar
Gen5
Loosen the clamp for the grommet at the base of the shaft. Slide the grommet up the shaft. Apply grease to the shaft. Slide the grommet back down. Tighten the clamp for the grommet.
As I stated before, grease works better...
Old 06-20-2008, 03:53 PM   #12 (permalink)
I finally have cupholders
View JazzinV6's Photo Gallery
Same thing happens on my car. I don't even notice it anymore.
JazzinV6 is offline   Reply With Quote
